Page 15 of 20 FirstFirst ... 567891011121314151617181920 LastLast
Results 141 to 150 of 195
Thread: Steering Wheel Controls
  1. #141
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    100k is way too high. Try what god_of_cpu suggests which is around 500 ohms. That should work much better.
  2. #142
    Jan 2007
    Quote Originally Posted by Curiosity View Post
    Thank you.
    I try to put the value to 500 ohm. I will make to know you!
    Simone
  3. #143
    Newbie mobes's Avatar
    Sep 2001
    Leander, TX
    Curiosity, did you have any better luck with the Belkin adapter?
  4. #144
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by mobes View Post
    I can't remember now but I think the Belkin was the worst. Both USB adaptors had resistors for protection which messed things up. They aren't designed for accuracy or low resistance and you only get a 0 to 127 range to work with, so it's a lot of trouble getting it to read different voltages for each button that are far enough away from each other in a 0 to 2.5v range.
  5. #145
    Sep 2001
    Leander, TX
    Alright, I won't buy one. Thanks!
    It's looking more and more like a PIC might be in order since I don't have a joystick port or room for a PCI card.
  6. #146
    Aug 2006
    Ok I've just read this whole thread and I just want to check I've got things right in my head.
    I have a laptop based car pc so gameport is not an option.. it must be usb.
    Am I right in thinkin I can get one of these: http://cgi.ebay.co.uk/DUAL-ACTION-DI...QQcmdZViewItem
    and simply wire up my cars steering wheel button line into one of the analog sticks - I understand that there are extra resistors etc too.. but I want to check I have got the basic understanding before I buy a gamepad.
    Cheers
  7. #147
    Mar 2004
    Florence Yall, BFKY
    Yes, that should work. I used a USB gamepad first, and it worked reasonably well.
  8. #148
    Aug 2006
    Thanks Curiosity.. I've just purchased one of those pads
    Are there any diagrams around on how to wire this up, I was looking last night and most of the links were dead
    Any advice would be most welcome!
  9. #149
    Mar 2004
    Florence Yall, BFKY
    Figure out which is input 0. It should be the left up/down. The pot connected to it is usually a 10K. Check it with a meter to find the ground and +5V on the outside pins, and the center tap is the input. Then just remove it and solder some wires there, or put the resistors there and wires.
  10. #150
    Aug 2006
    Thanks man, I'm glad we have people like you around here who know what they are doing
    I'll have a play around once the pad arrives..
  1. steering wheel touch screen monitor??
    By thecar-puter in forum LCD/Display
    Last Post: 07-11-2008, 03:56 PM
  2. Keeping steering wheel controls with new HU
    By pogue1000 in forum General Hardware Discussion
    Last Post: 01-14-2004, 12:24 PM
  3. Steering wheel controls thru serial or usb?
    By welthqa in forum General Hardware Discussion
    Last Post: 01-14-2004, 12:20 PM
  4. Buttons on steering wheel to work with computer?
    By slboytoy in forum Input Devices
    Last Post: 10-21-2003, 12:40 PM
  5. FS Pioneer Steering Wheel Remote CD-SR80
    By Sh0cker in forum Classified Archive
    Last Post: 10-02-2003, 09:48 PM
