Page 16 of 20 FirstFirst ... 67891011121314151617181920 LastLast
Results 151 to 160 of 195
Thread: Steering Wheel Controls
  1. #151
    Jan 2007
    Quote Originally Posted by simbau View Post
    Thank you.
    I try to put the value to 500 ohm. I will make to know you!
    Simone
    I have verified with the resistor from 500ohm, but I have not obtained good I turn out to you.
    The software SWC the behave myself optimally, but for the values of the key enter and of key + he does not succeed to pick up marks them, because the values to are too much similar.
    It tares the values optimally for the key enter and volume “+” wraps it of the values is too much near from 100 90.
    How I can resolve this my problem?
    Simone
  2. #152
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Each time you change resistors you should calibrate the joystick in control panel. See if that helps.
  3. #153
    Jan 2007
    Quote Originally Posted by Curiosity View Post
    Sure!
    I have always carried out the setting of the joystick on the panel of the control. I have always calibrated the joystick with the control panel, every time that I carried out the change of resistance.
    I use joystick 2 axes and 2 buttons, I bore the keys of the sterring wheel command, and the joystick turns out centers them!
    Software SWC reads to equal values for the key Volume + and that one of the key enter, is too much similar!
    SWC reads the remaining values of keys correctly
    Help!
    Simone
  4. #154
    Mar 2004
    Florence Yall, BFKY
    What numbers do you see for each button and with no button? Maybe that can help me figure out what's going on.
  5. #155
    Jan 2007
    The values of the resistances of mine steering wheel command are:
    “ENTER”, “+” and “-” switch resistance
    All switches released (OFF): 4700 - 5600 kΩ I read 5,17k
    A) “ENTER” switch (1) pushing on (ON): 50 - 60 Ω I read 0,06K
    B) “+” switch (2) pushing on (ON): 120 - 140 Ω I read 0,13K
    “-” switch (3) pushing on (ON): 220 - 260 Ω I read 0,24K
    “MODE”, and switch resistance
    All switches released (OFF): 4700 - 5600 kΩ I read 5,17K
    C) “MODE” switch (4) pushing on (ON): 370 - 460 Ω I read 0,42K
    D) witch (5) pushing on (ON): 680 - 820 Ω I read 0,7K
    switch (6) pushing on (ON): 1400 - 1700 Ω I read 1,57K
    SWC reads the values of enter and those of volume + or - too much near.
    THANK YOU
    SIMONE
  6. #156
    Mar 2004
    Florence Yall, BFKY
    Are you using babblefish? That thing is goofy.
    What values do you get for each button in SWC?
  7. #157
    Jan 2007
    Excuse for my English! I use the translator of google!
    Swc reads the following values: with resistor of 500ohm
    key ENTER: 100 - 100;
    Key +: 100 - 96..98;
    key -: 96 - 92;
    key mode: 86;
    key > 72;
    key > 60;
    I have problems to shape key + and the key enter, the key - he does not create problems!
    Thanks for your patience… I am in difficulty also with the language!
    Simone
  8. #158
    Mar 2004
    Florence Yall, BFKY
    Yoda-like are translators. Suck they do.
    So the connection to the steering wheel is like this right?
    +5V ---<500ohm>---- Steering wheel wire 1
    Joy X ---Steering wheel wire 1
    Steering wheel wire 2 ---<500ohm>---Gnd
    I'm having trouble with math today. Between 50 ohms and 120 ohms should be enough of a difference. Anyone else that can help?
    Edit: I think a 100 ohm will work better:
    Steering wheel wire 2 ---<100ohm>---Gnd
  9. #159
    Jan 2007
    I use this system:
    pin 1 --+----------+
    ........ Z..............|
    . . . . . Z 500 ohm ==== swc
    pin 3 --+----------+
    pin 6 --+
    ......... Z
    ........ Z 500 ohm
    ..........Z
    pin 8 --+
    I try with resistor from 100 ohm
    Thank you
    Simone
  10. #160
    Mar 2004
    Florence Yall, BFKY
    That may be very noisy because it is not grounded. Try this.
    pin 1 --<500>---+---SWC1
    pin 3 -----------/
    pin 4 --<100>--------SWC2
  1. steering wheel touch screen monitor??
    By thecar-puter in forum LCD/Display
    Last Post: 07-11-2008, 03:56 PM
  2. Keeping steering wheel controls with new HU
    By pogue1000 in forum General Hardware Discussion
    Last Post: 01-14-2004, 12:24 PM
  3. Steering wheel controls thru serial or usb?
    By welthqa in forum General Hardware Discussion
    Last Post: 01-14-2004, 12:20 PM
  4. Buttons on steering wheel to work with computer?
    By slboytoy in forum Input Devices
    Last Post: 10-21-2003, 12:40 PM
  5. FS Pioneer Steering Wheel Remote CD-SR80
    By Sh0cker in forum Classified Archive
    Last Post: 10-02-2003, 09:48 PM
