Page 17 of 20 FirstFirst ... 7891011121314151617181920 LastLast
Results 161 to 170 of 195
Thread: Steering Wheel Controls
  1. #161
    Jan 2007
    Quote Originally Posted by Curiosity View Post
    That may be very noisy because it is not grounded. Try this.
    pin 1 --<500>---+---SWC1
    pin 3 -----------/
    pin 4 --<100>--------SWC2
    ok I try your solution!
    thanks you.
    Mine swc it is composed from a single cable:
    Wheel-------swc============
    Simone
  2. #162
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    You should have 2 wires so you can complete the circuit, unless it is grounded somewhere. The electricity must flow from source to ground somehow or the values will not change. For example (5V-<500ohm>-X) X=5V, but (5V-<500ohm>-X-<500ohm>-Gnd) X = 2.5V
  3. #163
    Jan 2007
    excuse but I want to say:
    I have two cables that go to the sterring wheel.
    Only cable composed from two cables.
    A positive one and leads current to the resistors the other transmits the values!
    I have a doubt the values of the commands of the steering are read for +12v… the port game joystick has only +5.
    It is not that values +5 to the resistors of series give annoyance?
    I try with your solution!
    Thank you
    Simone
    I MUST ONE PIZZA AND BEER TO YOU!!
  4. #164
    Jan 2007
    pin 3 -----------/
    Your solution does not work!
    The gameport of the creatives sound blaster it sees the “joystick” but in the control panel, I cannot make the configuration,
    as soon as I press the keys does not recognize the joystick.
    Simone
  5. #165
    Mar 2004
    Florence Yall, BFKY
    That is not good. I guess your old way works better, but I don't see how. Maybe try resistors a little higher or lower to see which works better?
  6. #166
    Aug 2006
    Well I've just got my new car and had all the bits ready to put this in.. then I find out the headunit connects up by CANbus connector..
    I was hoping that the SWC would just be on their own wiring like my old car but I think they are all bundled into this canbus thing.
    Here is the pinout of the factory headunit which works with the SWC..
    Anyone know anything about this CANbus stuff.. can I still interface my carPC with the SWC?
  7. #167
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    Maybe the PAC Audio SWI-CAN will do what you need.
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
  8. #168
    Aug 2006
    I did wonder if PAC did some sort of lead but when I looked they don't do anything covering my car I guess its because they are a US company.
    My car is a Vauxhall/Opel Astra H
  9. #169
    Aug 2006
    Ok, I've just had another thought..
    There are some companys here in the UK that make the SWC adaptors for my car to interface with Sony,Pioneer,Alpine headunits etc.. so the only problem is getting something to the PC.
    Now I'm guessing that these headunits may work on the varying resistance method seen as some of them only have a few wires.. so could I get one of those adaptors say an alpine one for example, then hookup the alpine signal onto the USB SWC Joystick adaptor?
    Not exactly the neatest way but as long as I get to keep my SWC
    So anyone got any thoughts on that, or know which stereo manufacturers (if any) would work with the joystick adaptor?
    Cheers
  10. #170
    Oct 2005
    Hou. TX
    I had pretty good sucess with using a universal IR reciever on the PC and a PAC SWI-X that output a IR signal. You might need to give PAC a call about your particular car.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  1. steering wheel touch screen monitor??
    By thecar-puter in forum LCD/Display
    Last Post: 07-11-2008, 04:56 PM
  2. Keeping steering wheel controls with new HU
    By pogue1000 in forum General Hardware Discussion
    Last Post: 01-14-2004, 01:24 PM
  3. Steering wheel controls thru serial or usb?
    By welthqa in forum General Hardware Discussion
    Last Post: 01-14-2004, 01:20 PM
  4. Buttons on steering wheel to work with computer?
    By slboytoy in forum Input Devices
    Last Post: 10-21-2003, 01:40 PM
  5. FS Pioneer Steering Wheel Remote CD-SR80
    By Sh0cker in forum Classified Archive
    Last Post: 10-02-2003, 10:48 PM
