Page 19 of 20 FirstFirst ... 91011121314151617181920 LastLast
Results 181 to 190 of 195
Thread: Steering Wheel Controls
  1. #181
    Aug 2006
    Curiosity:
    Thanks so much!
    I hooked up the joypad to my Sony adaptor I purchased for my car as you described and IT WORKS FLAWLESSLY!!!
    I did as you suggested and checked for voltage across the the ground of the joypad and the ground of the Sony adaptor and I found 0.13v... could this cause a problem in the longrun ? Is there anything I can do about it?
    I only found this voltage when the laptop was powered using the incar charger, it was 0v when on battery..
    I'm soooo pleased it works, thanks for your help!!!
  2. #182
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    It should be fine. If it was like 1-50V it would have been a big problem. 0.13V may cause a little ground hum at high volume. If so, you may want to ground the laptop better.
  3. #183
    Aug 2006
    Awesome, just wanted to double check I wasn't slowly cooking my ECU or anything
    Thanks for all the advice, I really owe you one
  4. #184
    Jun 2003
    Chicago
    Quote Originally Posted by Curiosity View Post
    With a normal ADC like the K8055 it's pretty simple and more stable than a gamepad. I've used both. All you need to do is connect 1 wire to 5V off the device (I'm sure it's there) and the other wire to the analog input. If it jumps around with no buttons pressed, just put a 100K resistor between the input and ground. That's all you need.
    I've previosly gotten this working when I used a soundcard with an integrated gameport. I'm not too concerned about hooking up the Sony X4S to the K8055 but I am curious about the amount of DLL modifications required.
    How much .dll tweaking is required for windows to recognize the K8055 as a gameport device?
  5. #185
    Mar 2004
    Florence Yall, BFKY
    There are a few K8055 plugins for frontends and some have source. Just search the forum.
  6. #186
    Newbie gurob's Avatar
    Feb 2007
    please, who knows how to calibrate the SWC? what to do when it asks center position?
  7. #187
    Jan 2007
    is there something like standard resistances for steering wheel buttons?
  8. #188
    Aug 2006
    Columbus, OH
    This scrip works excellent. Zorro is an excellent coder (well we all know that since he made phoco).
    But I have an annoying issue: when the computer goes to standby, it upset the scrip and gets a red X and it shows "ERROR - Joystick Connection"
    I'm using an eliminator gamepad. Did anyone experienced the same?
    Any help its really appreciate.
  9. #189
    Aug 2006
    Columbus, OH
    Pls Help
    Bump.
    No one helping with the "ERROR - Joystick Connection"
    Mike.
  10. #190
    May 2009
    There is CarPC JoyCon that converts steering wheel controls into USB keyboard.
    Resistance output steering wheel controls can be directly connected.
  1. steering wheel touch screen monitor??
    By thecar-puter in forum LCD/Display
    Last Post: 07-11-2008, 03:56 PM
  2. Keeping steering wheel controls with new HU
    By pogue1000 in forum General Hardware Discussion
    Last Post: 01-14-2004, 12:24 PM
  3. Steering wheel controls thru serial or usb?
    By welthqa in forum General Hardware Discussion
    Last Post: 01-14-2004, 12:20 PM
  4. Buttons on steering wheel to work with computer?
    By slboytoy in forum Input Devices
    Last Post: 10-21-2003, 12:40 PM
  5. FS Pioneer Steering Wheel Remote CD-SR80
    By Sh0cker in forum Classified Archive
    Last Post: 10-02-2003, 09:48 PM
