All the digrams I used were in the AUDIO VISUAL, NAVIGATION & TELEPHONE SYSTEM section. I attached them below.
Looks similar enough... On your diagram it looks like youll just have to connect line 29 to 5v from the gameport, and lines 27 and 26 to the axis lines. After you do that just throw in any old resistor between 10 and 1000 ohms onto your axis lines with the diodes, I think I ended up using 270 ohms, then connect it to your gameport and create a 2 axis joystick in the XP control panel. After you have the joystick created goto properties for it, then click the settings tab, click calibrate follow the wizard along until you get to the axis calibration page. Click the display raw data check box and start pressing your steering wheel buttons, you should get different axis values when you do. You'll know you used the right resistor when the value when no buttons are pressed is not much greater then the values when a button is pressed. i.e. 20, 25, 30, 35 would be good values for three buttons and the no button depressed state where 20, 25, 30, 100 would mean the resistor your using is probably too big.
LinkBack URL
About LinkBacks
