Page 4 of 20 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 195
Thread: Steering Wheel Controls
  1. #31
    Nov 2003
    Did you connect it to a game port on a sound card or motherboard or are you using a usb converter?
  2. #32
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by Curiosity
    What's with the "Power" on the left? It already has +5V on it, so if you disconnected that it seems like it would work better. I'm assuming it's +12V from the car?
    The power on the left is actually for the line on the steering wheel that accepts the +5v power from the game port and is routed through the steering wheel controls and output to the lines for it... it's recieving power not supplying. If you disconnect it, it definitly won't work.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  3. #33
    Jan 2004
    Lorenzo,
    Your diagram looks good and if your getting those resistance values from your steering wheel controls, your car should be compatible. However, as Izik said, the problem may lie in your game port. Apparently the USB adaptors may not be able to detect the resistance at the ohm level. I have neither confirmed nor denied this myself though. If possible, I would suggest trying a PCI based sound card with a game port as it's the only thing that I have confirmed works at the ohm level.
  4. #34
    Jan 2004
    It *may* be possible to get a USB game port adaptor to work if you first build the voltage to current converter circuit found at the bottom of this page, but this is just a guess.
  5. #35
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi well this looks pretty impressive. and well just wanted to know will this SWC work on all cars that have a control on steering wheel. Like the SKODA.. and is it still on test phase or fully working.. If its owrking i am willing to pick it up if u ship it to INDIA
  6. #36
    Jan 2004
    The only cars it will work on are those that communicate by varying current when a button is pressed on a steering wheel. This should include most, if not all them listed in the SWI-X PDF file linked earlier in this thread. I can't say anything about cars not in the PDF. The way to confirm any car is just take a voltmeter to the control lines in your car and see what happens to the resistance when you connect it up.
    There is also nothing to buy from me. All you need to do this is a couple standard resistors and diodes and some wire. It doesn't require any ICs as I originally thought it might. You should be able to get all the parts you need from radio shack or someplace like that for < $5.
  7. #37
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    I tried to use my car's steering wheel controls..
    But i have a problem...
    it has 4 wires.. ACC,GROUND,TX+ and TX-.
    I connect +12v to ACC ground to GROUND and then check volts to TX+ and TX-..
    But the volts don't change!!
    Either 2,5 and 12V...
    Am I doing something wrong??
  8. #38
    Jan 2003
    Ruston, LA
    Quote Originally Posted by DjBac
    Sounds like you have digital controls.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #39
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    I just use the vol,track and scrol wheel off my logitech keyboard attached to my wheel.
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
  10. #40
    Quote Originally Posted by god_of_cpu
    Heres the circuit diagram without the relay.
    If you have more then 2 wires for your controls, you will just need to add a resistor and diode for each additional wire and hook it up in a similar way. You will be limted to 4 wires since the joystick port only supports up to 4 axises.
    Also, the diagram states a 500 ohm resistor, but this is not set in stone. You may have to use something other then a 500 ohm resistor to get the best voltage values, but probably anything from 10 ohm = 1k ohm will work at some level.
    Would it be possible to use a double pole switch with one pole through the 500 and the other through the 1K to double the number of buttons you can use?
  1. steering wheel touch screen monitor??
    By thecar-puter in forum LCD/Display
    Last Post: 07-11-2008, 04:56 PM
  2. Keeping steering wheel controls with new HU
    By pogue1000 in forum General Hardware Discussion
    Last Post: 01-14-2004, 01:24 PM
  3. Steering wheel controls thru serial or usb?
    By welthqa in forum General Hardware Discussion
    Last Post: 01-14-2004, 01:20 PM
  4. Buttons on steering wheel to work with computer?
    By slboytoy in forum Input Devices
    Last Post: 10-21-2003, 01:40 PM
  5. FS Pioneer Steering Wheel Remote CD-SR80
    By Sh0cker in forum Classified Archive
    Last Post: 10-02-2003, 10:48 PM
