Page 5 of 20 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 195
Thread: Steering Wheel Controls
  1. #41
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by frodobaggins
    Sounds like you have digital controls.
    But when I press a button nothing happens!!
    So there is no way to use them??
  2. #42
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    You sure you're looking at the right wires? If so and it's really digital, you probably need a scope to see what's really going on. Too much trouble IMO. A PAC interface and IRMan would probably be a better choice for something like that though, right?
  3. #43
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Quote Originally Posted by DjBac
    I tried to use my car's steering wheel controls..
    But i have a problem...
    it has 4 wires.. ACC,GROUND,TX+ and TX-.
    I connect +12v to ACC ground to GROUND and then check volts to TX+ and TX-..
    But the volts don't change!!
    Either 2,5 and 12V...
    Am I doing something wrong??
    That sounds okay to me. When god_of_cpu hooked up 5V to his controls he also would get three voltages (1.5V, 3V, and 5V) to correspond to mode, vol up, and vol down. The changing voltage is actually changing the current.
    Yours should work fine!
  4. #44
    Quote Originally Posted by MSUC5Vette
    Would it be possible to use a double pole switch with one pole through the 500 and the other through the 1K to double the number of buttons you can use?
    Meant to say double throw switch, does any one know if it will work.
  5. #45
    Jun 2004
    GREECE/Athens
    I have the controls out of the car and testing them with a 12V power supply...
    They have only 4 wires...
    ACC, GROUND and TX+/-
    I've used PAC SWI-X and IRMan but with no result!!
    Voltage WON'T change!!! That is the problem!!!
    Is there a way that the control don't work??
    I have an aftermarket HU and I don't know!!!
  6. #46
    Apr 2003
    HOT Arizona
    Oh, I thought you were getting 2, 5, and 12V when you pushed buttons. I guess if you have TX+/- then those are digital.
  7. #47
    Mar 2004
    Florence Yall, BFKY
    Does the PAC SWI-X work? Easy way to test: Just look at the IR emitter through a digital camera/video camera. They all pick up IR. To test the IRMan, use any other remote from a TV or stereo. If both work, I have no more ideas.
  8. #48
    Jun 2004
    GREECE/Athens
    I've tested SWI-X and works fine!!
    I use IRMan with another remote, so it is just fine!!!
    If my controls are digital, how can I make them work?
  9. #49
    Mar 2004
    Florence Yall, BFKY
    So if you use a TV remote you get events in Girder, and the SWI-X flashes the IR emitter when you press buttons on the steering wheel but you get no events in Girder? Maybe incompatible IR signal or something? Anybody??
  10. #50
    Jun 2004
    Queens, New York
    sorry i didnt read this whole thread. i couldnt stop laughing after i looked at god of cpu's site. ...junior roflmao.
  1. steering wheel touch screen monitor??
    By thecar-puter in forum LCD/Display
    Last Post: 07-11-2008, 04:56 PM
  2. Keeping steering wheel controls with new HU
    By pogue1000 in forum General Hardware Discussion
    Last Post: 01-14-2004, 01:24 PM
  3. Steering wheel controls thru serial or usb?
    By welthqa in forum General Hardware Discussion
    Last Post: 01-14-2004, 01:20 PM
  4. Buttons on steering wheel to work with computer?
    By slboytoy in forum Input Devices
    Last Post: 10-21-2003, 01:40 PM
  5. FS Pioneer Steering Wheel Remote CD-SR80
    By Sh0cker in forum Classified Archive
    Last Post: 10-02-2003, 10:48 PM
