Results 1 to 3 of 3
Thread: Xenarc mouse cursor positioning bug?
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    I have a Xenarc 700TS on an Epia M10000Neh. When using a mouse (I've tried several) and hover over "some" items on application dialog boxes, the visible cursor jumps down from .25" to 1.5" below the actual point of focus for the mouse. This only happens at some places on some dialogs, usually whenever the cursor changes to a pointy hand or a two-sided-horizontal arrow, but not always. If I change monitors, no problems. If I control the pc with VNC, no problems. Only when I use the local mouse on the Xenarc. I called Xenarc and the tech said he'd never heard of anything like that. I installed the latest bios and vga drivers but it didn't help (also I still can't get 16:9 display in Win2k). Anybody have Xenarc/Epia and have you seen this problem?
    Newbie OrangePeel's Avatar
    Nov 2003
    Wellington, New Zealand
    Nope, my USB Logitech mouse works fine with the Xenarc connected. I can use both fine... Which Touchkit software are you using? The stuff from the CD? Or one of the newer ones?
    89 Celica, CarPC installed, 1st bday :)
    http://www.fishy.net.nz/carpc/
    • MediaEngine
    • Epia V8000
    • 80GB WD 7200RPM HD
    • Xenarc 700TS
    • SB Live
    • Opus 90W
    • CIMR100 remote
    • Deluo serial GPS
    • D-Link USB radio wired to power antenna
    Mar 2004
    Los Angeles Area
    I downloaded the latest touchkit (3.2.0.2731) from the Xantech website but it didn't help either.
  1. Replies: 15
    Last Post: 03-03-2004, 11:53 AM
  2. usb mouse stops working
    By corsamel in forum General Hardware Discussion
    Last Post: 10-18-2003, 05:53 AM
  3. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 06:38 AM
  4. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 03:11 PM
  5. Xenarc 7" Touchscreen VGA Group Buy.
    Last Post: 07-27-2002, 10:52 AM
