The one I have dosn't work either. Stay away
http://www.newegg.com/app/ViewProduc...107-107&depa=0![]()
Man who stands on toilet is high on pot
Co-Developer of A.I.M.E.E
www.aimee.cc
Yes, tried it on the 2.0 hob in the car, directly off the 2.0 port in the car, and on the 2.0 hub in my house on 3 of the 4 ports. Also tried using the power supply that came with it, and a molex from both pc's. CD or drivepowers up. I can open the cd door, hear it spin the cd. it just doesn't recognize the drives. Also tried it on a good hard drive last night with same outcome. you could hear drive spin up, but XP listed it as "unrecognized device"Originally Posted by Confused
Sam
Batman@TheNewBatcave.com
AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
www.samshomepage.net
www.Cars-N-Computers.com
Drive powers up but it's not detected? You did plug in the little power plug to the back of the adapter, right? (Sorry if you have, but from what you said, it seems like you haven't).Originally Posted by Batmanatthenewb
Mine wouldn't be detected until that was plugged in.
Garry
www.aimee.cc
what did you set the jumper as Master / Slave / Cable select? My CD-RW wouldn't be detected by my firewire enclosure until i put the jumper on cable select try that first
Yes,Originally Posted by Confused
Tried powering throughPower Supply and through the power supply that came with the adapter.
Sam
Hcomplyr,Originally Posted by Hcomplyr
Jumper was set as master. Tried as CS and slave with no difference in detection, so I put it back to master where it was supposed to be..
Sam
Well it was worth a shotOriginally Posted by Batmanatthenewb
That's the exact same one I have, the GWC model. Its been working quite well. Drive needs to be set to master. And you'll need power to the drive, and to the adapter. Are you sure the converter your using on the slim drive isn't the problem?
GezusK,Originally Posted by GezusK
Don't see how it could be. Removed the slim adapter and plugged USB/IDE converter directly into a hard drive (set as master). XP still sees it as unrecognized drive. Same thing if I plug into a full size dvd/cd or into the adapter to the slim dvd/cd. As mentioned earlier, the cd spins up, lights flash, and drawer opens and closes. XP just doesn't recognize it. It is looking for some sort of driver the error message says.
Thanks for your comments,
Sam
