Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Touchpad and Steering Wheel Controls (Toyota Corolla 2001 european edition)
  1. #11
    Jun 2006
    there are a series of resistors in the steering wheel control. so a different voltage gives a different output. only way i think you can find out is with a circuit diagram or with a multimeter.
  2. #12
    Apr 2008
    Quote Originally Posted by nrgizerbunny View Post
    OK, lets say , that I foind oout the outpouts. Then how can I connect with the 3 wires of my system?
    The 3 wires are :
    +3,3 V
    GND
    AD
  3. #13
    Jun 2006
    what is AD?
  4. #14
    Apr 2008
    what is AD?
    I think that is the wire , whitch it has the sognal , for the operations.
  5. #15
    Jun 2006
    tricky one,
    i've got an 05 corolla which has a similar set up. I had to connect ground to one wire and the +3.3v to the other 1 wire (its only a 3 wire system) and the sense to the final wire. Each time you press a switch you are going to get a different resistance coming down across the two ends. Just check to see if you have a ground there anywhere to start off with. If you haven't it doesn't matter which way you connect it up.
  6. #16
    Apr 2008
    tricky one,
    Thank you for your answer.
    But I don't understand what you said to me. Could you please explain to me better?
    Thank you!
  7. #17
    Jun 2006
    there is one wire that goes to the touchpad, this provides +12v, one wire is ground. Now in my case the remaining wire is used to sense the voltage drop. I think yours has two to sense the voltage drop. hope that makes sense.
  8. #18
    Apr 2008
    OK I understand. But I have a couple of questions
    First of all the wire from my head unit says +3.3V . Where should I connect it?
    Second , There are 2 wires for control and the head unit has only one. What could i do for that?
  9. #19
    Jun 2006
    I would connect the +3.3v to the top rail on the touch pad. ground is one wire and the two sense wires must be the remaining two. I think you have got a facelift loom.
