Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Steering wheel remote controls...
  1. #11
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    Hmmmm a 4 year old review????? it is available out there http://www.bleedingedgecomputers.com...D=1398&c=19755
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
  2. #12
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    My carputer is being built into a confined space. At this point, adding a PCI is not an option.
    So what about the PAC + IR USB + Girder? Girder is meant to work with IR. The only issue is that the FIR connector is not compatible. So the last option for me is an external IR interface. It seems simple enough... "seem" being the operative word.
    When I get off work (yes I'm working on a Sunday and it sucks), I'll sign up to Girder's forum and see if anyone there knows of anything that could be used.
  3. #13
    Newbie zummi's Avatar
    Jul 2004
    Sotra, Norway
    Do I have to use IR-connection in order to use Girder, or can I connect the steering wheel remote to the computer through the COM-port?
    My ride (norwegian)
    -92 CitroŽn XM 2.1TD / MII10000, 7" TS, 150W Opus, WLAN, GPS, BT / Infinity REF5760A, RockfordFosgate Speakers + 2 subs
  4. #14
    Jun 2004
    Toronto, Canada
    You can't just hotwire it from what I know. You would have to build a small interface of some kind.
    This seems like something that needs a simple step-by-step solution. I have found a lot of people with a lot of different ideas, but none were plug-and-play or suitable for every sittuation.
    This carputer stuff is very new and there seems to be a lot of gaps that needs filling. But there are a lot of smart people here, and it's just a matter of time before simple solutions are realized.
  5. #15
    Jun 2004
    Toronto, Canada
    It looks like what I may need is a USB-UIRT with the PAC SWI-X, along with girder.
    http://www.usbuirt.com/order.htm
    There are other USB IR's that I came across. I may post other findings later. So far there are solutions, but nothing cheap.
  6. #16
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    wanna build a USB interface yourself?
    that would be cheap.
    http://www.cesko.host.sk/IgorPlugUSB/IgorPlug-USB%20(AVR)_eng.htm
    I built one and it works great. only thing is you need to "register" the shareware driver.
    -Mars
  1. Steering Wheel Controls
    By god_of_cpu in forum Input Devices
    Last Post: 06-23-2009, 12:14 PM
  2. 2004 Jetta Factory steering wheel controls
    By Zip-Lock in forum Input Devices
    Last Post: 06-28-2006, 03:10 AM
  3. Steering wheel controls for FP
    By ddogg_777 in forum FrodoPlayer
    Last Post: 07-22-2004, 04:26 PM
  4. Steering wheel controls
    By Izik in forum Input Devices
    Last Post: 05-31-2004, 10:46 AM
  5. Keeping steering wheel controls with new HU
    By pogue1000 in forum General Hardware Discussion
    Last Post: 01-14-2004, 01:24 PM
