Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
Thread: Motorized Door To Cover The Lilliput LCD
  1. #31
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    I'm thinking like a big lense iris.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
  2. #32
    Constant Bitrate Xtreme2k2's Avatar
    May 2004
    NJ
    Quote Originally Posted by EBFoxbat
    Isnt there a cleaner way then an old CDROM ?
    Probably is, I had an old CDROM laying around so I thought, what the hell, I'll give it a try
    I still have the circuit board and all the parts, I just need to wire them back up again.
    I can probably code something in C++ to open/close the tray.
    Have it run at startup, and shutdown.
  3. #33
    May 2004
    NJ
    another thought..
    Would there be anyway to re-wire the actual eject button to either the serial or parallel port and activate it that way?
  4. #34
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    You could use a small linear actuator it would be a lot smaller than a CD drive. You could basically use the same controller as in the CD drive. Even the power switch could be tied into the actuator control.
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
  5. #35
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    yeah extreme2k you could use a capacitor to flip a relay momentarily to "push" the power button. it'd probably require more than one relay tho /shrug
    CarPC install is starting to come along again...
  6. #36
    Registered User Chronyx's Avatar
    Jul 2004
    Surrey, England
    Why not just use a transistor to electronically 'press' the eject button?
    That's my understanding of what a transistor does anyway... It could be powered by USB, parallel, serial...I think
  7. #37
    Jul 2004
    I'm affraid that in you're country another way of drawing is used as here.
    The way I drawed the first scheme is our way to draw a relays.
    With a square box, with al the contacts in a horizontally row.
    But I understand you drawing now.
    And basicly i think it's the same as mine, but I have used a relais contact were you used 2 diode's.
    I like the IDE sollution also...
    I don't know what i'm going to use.
    I do know what I'm going to use as cover.
    I'll use the front of an old (flat) radio.
    An old Blaupunkt radio.
    When I remove the 2 buttons (could replace them when i've cutted them 1cm shorter) i could gleu it on the cover.
    So it lookes like there's an old radio/cass. player installed.
  8. #38
    May 2004
    NJ
    Quote Originally Posted by MatthijsNL
    thats EXACTLY what I'm going to do
    oh, and so you guys get an idea where my LCD is going, heres a pic of the stock HU
    (if you're wondering where the shifter fork is, I was installing a short throw shifter, and took the pic )
  9. #39
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    http://www.rjlsoftware.com/software/.../default.shtml
    This will open/close run program via command prompt.
  10. #40
    Jul 2004
    heh
    Quote Originally Posted by Ill1
    yeah.. and in linux THIS would open the cd;
    eject
  1. Anyone found motorized in-dash VGA lcd screen
    By plaiming2 in forum LCD/Display
    Last Post: 07-20-2004, 06:16 PM
  2. Motorized LCD Display - CD ROM
    By Gauderio in forum LCD/Display
    Last Post: 06-20-2004, 02:50 AM
  3. Rolling Verticle Waves in Lilliput VGA LCD
    By antimatter in forum LCD/Display
    Last Post: 01-26-2004, 08:28 PM
  4. Can you buy motorized LCD brackets?
    By pigseye in forum General Hardware Discussion
    Last Post: 12-27-2001, 01:43 AM
  5. motorized lcd cover
    By new0deal in forum General Hardware Discussion
    Last Post: 11-08-2000, 06:50 PM
