Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 52
Thread: Motorized Door To Cover The Lilliput LCD
  1. #41
    Constant Bitrate Xtreme2k2's Avatar
    May 2004
    NJ
    I might need to take code from that program I posted and code my own program to do this.
    I'm not sure if windows would recognize it as a drive, considering all the major components (reader and ****) arent there.
    I might need to code it to send the command to the specific device, and not the drive letter itself
    or no?
  2. #42
    Jul 2004
    Yeah!
    I'm going to use that!
    So i can use my remote to open/close it!
    So when i wan'to pimp, i don't need to shut down the whole system!
    I'll leave the board of the cd-rom in the computer, so i don't have to **** out-of-range-IDE-cables, and just bring the 5 wire's of the motor/switches tot the dash!
    I'm going to use a DVD-rom here.
    HAHA Cd-rom is for pussy's!
    (Correction: i only have a broken DVD-rom at here...)
  3. #43
    May 2004
    NJ
    Quote Originally Posted by MatthijsNL
    Yeah!
    hey, its an old cdrom from a gateway 2000 that I was taking apart (time to do some ******* cleaning around here, and take out the trash )
    Says it was manufactured in 1993
    Oh, and its not really a CD-ROM anymore, I've taken all the components that actually spin/read the disc out, so now its just a motorized tray
  4. #44
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    Without the ide cable, the drive will not be recoginized by the OS. I'm not sure what would be required to have the OS assign a drive letter to the CD player. I would take a guess and say that it reads some firmware off of the drive and then makes sure that it has drivers installed for it and then goes from there. I know that dealing with HDD, the Firmware and Serial # are read from the disk platter itself. As for a CD drive, since there is no platter, I would assume the Firmware and Serial # are stored on one of the circuit boards. I would just give it a go and plug the drive up to your computer to see if it is recoginized. Then play with it from there. If you can't get it to recoginize the drive, then the next step I would take would be to figure out how to send a Line High through your serial or parallel port.
  5. #45
    May 2004
    NJ
  6. #46
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    Quote Originally Posted by xlarge
    yeah.. and in linux THIS would open the cd;
    eject
    Great first post champ.
    You've really added value here.
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
  7. #47
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    as far as i can see- no one has mentioned this. There is a pain in the *** thingy in there that usually 'locks' the cd drive in.
    Are you leaveing this in? it happens when the drive is almost completly retracted.
  8. #48
    Jul 2004
    Didn't think of that one!
    But when using IDE it's not a problem at all.
    When using just the 'machinery' i think it's pulled back when a current apears on the open/close line's.
    If not, an other line is used for this.
    One of the 5 wires.
    Can not be on the board (in the IDE) , becouse that's not part of the 'machinery'.
    And if it's cousing trouble, we could always remove it...
    Don't think it's going to be a problem...
  9. #49
    May 2004
    NJ
    I took that stupid piece of plastic out, it was annoying, kept locking when it was fully closed
  10. #50
    Jan 2004
    you know I think I'm just going to go to the local toys r us or wal-mart and see if I can't find a toy that has a motorized door somewhere... then hook up some sort of relay and integrate all the info on this thread as far as coding goes.
    2002 Subaru WRX - Silver
    -FP18G turbo
    -Walbro fuel pump
    -Modified OEM 840 CC Injectors
    -TurboXS: UTEC, turboback, uppipe, intake
    -Blitz FMIC
    -STI cluster
    -17"x7.5" SSR Competitions
    -Tein Flex coilovers
    -NOS 50 shot
    -2004 rear conversion
  1. Anyone found motorized in-dash VGA lcd screen
    By plaiming2 in forum LCD/Display
    Last Post: 07-20-2004, 06:16 PM
  2. Motorized LCD Display - CD ROM
    By Gauderio in forum LCD/Display
    Last Post: 06-20-2004, 02:50 AM
  3. Rolling Verticle Waves in Lilliput VGA LCD
    By antimatter in forum LCD/Display
    Last Post: 01-26-2004, 08:28 PM
  4. Can you buy motorized LCD brackets?
    By pigseye in forum General Hardware Discussion
    Last Post: 12-27-2001, 01:43 AM
  5. motorized lcd cover
    By new0deal in forum General Hardware Discussion
    Last Post: 11-08-2000, 06:50 PM
