Results 1 to 7 of 7
Thread: hard to describe what i'm looking for... bypass keyboard?
    Variable Bitrate nadir_s's Avatar
    Oct 2002
    San Jose, CA
    hi guys
    i'm looking for something to bypass the keyboard check when the computer first starts up... like maybe something i can plug into the USB or PS2 port. I get this keyboard error check when I don't have a keyboard plugged in. How can i by pass that? Is there some tiny device i can plug into those ports to fool it? Any help would be much appreciated! thanks
    [ 5-spd 1996 M A X i M A SE ]
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    set the bios to "not halt on keyboard error "
    I think from what you are describing that your pc doesnt boot when the keyboard is missing ?
    there should be a setting in the bios to overcome this
    dont need no hardware
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Oct 2002
    San Jose, CA
    Quote Originally Posted by SAScooby
    thanks, i'll look into it.
    but just in case... any ideas for hardware solutions? Maybe I can get one of those PS2 -> USB adapters and hack the wiring in it to fool the comp?
    Newbie BigRedBee's Avatar
    Jan 2004
    PDX
    Why not just use a cheap USB keyboard ? Even if a solution exists, it's likely going to cost at least as much as a keyboard itself......
    VIA EPIA M10000 | 7" Lilliput Touch VGA | PW70 | 256 Meg RAM | 20 Gig 2.5" drive
    Dual Battery with Optima Yellowtop | Hellroaring Battery Isolater
    ICOM 2720A| Delorme Earthmate GPS | Tiny Track APRS
    Survives Crank
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    easiest way is to do what sasscobby said set bios to not halt on either no keyboard or failing that not halt on all errors, secondly find an old keyboard remove the controller and wiring its about 3 inch long by 1 inch deep so no biggie and plug that in the ps2 style port that will fool the pc, but like i said try bios first!
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
    Oct 2002
    San Jose, CA
    okay got it guys! thanks alot!
  1. Laptop keyboard to the PS2 port....
    By claylong in forum General Hardware Discussion
    Last Post: 09-22-2007, 06:29 AM
  2. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 01:49 PM
  3. mini keyboard
    By Alphared in forum Input Devices
    Last Post: 07-27-2004, 10:32 AM
  4. A question about mounting a flexible keyboard
    By Rudical in forum Input Devices
    Last Post: 08-05-2003, 09:54 PM
  5. Disabling BIOS keyboard error?
    By Squeezer in forum General Hardware Discussion
    Last Post: 02-02-2001, 08:29 AM
