Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 2 part question (keyboard hacks)
  1. #11
    TX5
    TX5 is offline
    Sydney
    bugger, found some of the keys i want.
    good old trial and error...
  2. #12
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by TX5
    Just ripped apart an old keyboard i had around and plugged it into and old computer and tryed to figure out what combos i need.
    is there a list of the pin combo and what key they are for?? it would save a LOT of arseing around
    Sorry man, all keyboards are different. You'll just have to map out the keys you need. Takes some time, but ya know...
    Tidder
    Try RevFE
  3. #13
    For the Key combos ie 1-2 2-3....
    If I wanted one push button to hit both <alt> and D would I need a double pole momentary switch?
  4. #14
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    Quote Originally Posted by Tidder
    Why would you spend $30? I'd grab a cheap like $8 keyboard and use that. I do agree with you though, lots of soldering...
    Cause the controles look slick!! The vol controle is rotary and the ff/rwd next/back play/pause stop/eject all from 4 buttons.
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
  5. #15
    May 2004
    Michigan
    just had a quick question about the whole 'multiple button shortcuts.' If I wanted to double the amount of buttons I have, [ie. have a 'd' button and also an 'alt + d', could I have a toggle or push button switch wired to the 'alt' key and then the regular momentary to the 'd'? Would that work? Or would I have to just have two momentary switches and press both at the same time?
  6. #16
    Newbie Goa_Lud's Avatar
    Aug 2004
    Colombia
    Wink Keyboard
    If you want to do that, you have to map out all the keys that you need, takes. it's a little boring, but after all, and the most important, you know that you build it. . I have made one of these "modified" keyboard, only using the numeric keypad.
  7. #17
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by rdc_3200
    Yeah, that would work with a toggle or push on/push off button switch.
    Tidder
    Try RevFE
  8. #18
    May 2004
    Michigan
    awesome...thanks a bunch
  1. laptop keyboard question
    By smonice in forum General Hardware Discussion
    Last Post: 08-28-2004, 12:10 AM
  2. Interesting keyboard question
    By ruflyf in forum General Hardware Discussion
    Last Post: 02-09-2004, 05:34 PM
  3. A question about mounting a flexible keyboard
    By Rudical in forum Input Devices
    Last Post: 08-05-2003, 09:54 PM
  4. keyboard mapping question
    By jtk in forum General Hardware Discussion
    Last Post: 03-14-2003, 05:56 PM
  5. Question about creating a custom keyboard
    By Micahb in forum General MP3Car Discussion
    Last Post: 08-24-2002, 06:33 PM
