Results 1 to 10 of 18
Thread: 2 part question (keyboard hacks)
    Constant Bitrate chuckctv's Avatar
    Aug 2004
    Virginia
    (1) MAIN QUESTION..
    Does anyone know if a standard keyboard ;which i assume works on a grid using multiple resistant????; could have the keyboard removed and use switches with resisters attchached to create multiple button inputs that work off the keyboard, I would assume if this works then using the high function keys (<shift>-<cntl>-F) and so forth could be utililized more easily in our projects by actually placing small push buttons on the dash to activate/ect stuff on our carputers (software wise I mean).... Did I explain that well enough to be understood?
    (2) second question (important, but not as important as 1)
    any recomendations on the best on-screen virtual keyboard for touch screen? prefer something that not matter what application im in, I could just press a spot on the screen and a virtual keyboard pops up.
    My system will utilize the virtual keyboard mostly, but I do have a usb keyboard (w/trackpoint) that can be plugged in during more intense typeing.
    My screen is ELO-12" touch screen. system P3-933mhz (usb everything)
    screen is in the mounting stage.
    chuck
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    There is a small device that does exactly what you're talking about. You plug it into the PS/2 keyboard port of your computer, then solder switchs/buttons to parts of it that work as "keys". Then when you hit the switch/button, it presses that key for you. Sorry, but I can't remember what it's called right now... Hopefully someone else can give you name/link to it...
    Constant Bitrate bluehcc's Avatar
    Jun 2004
    Queens, NY
    2006 Camry
    Compaq Laptop
    Holux GPS Iguidance 3.0
    7" Xenarc Touch Screen
    Carnetix 1900 Power Supplied, Wireless b/g
    Oct 2002
    ipac - designed for MAME but I have a sneaking suspicion I'll be using one.
    Majik
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by chuckctv
    (1) MAIN QUESTION..
    Well, it's not a multiple resistant grid... It's atually set up just by pins. Each key has a different pin combo Like 1-2 1-3 2-3 2-12. The first carputer I did was with MPXF, and I was too poor for in IRman at the time, so I took apart a keyboard, mapped ALL the keys, and then just wired up the keys I needed to momentary push button switches from radioshack. Worked great! Mounted them all to a panel in my dash. It was pretty sweet.
    What you might run into though, is a lot of older keyboards have an actual board inside, instead of newer keyboards which just have a membrane. You need a keyboard with a membrane. Map the keys out that you need, solder in some wires, and voila, you got it!
    If you're like "wtf are you talking about" I'll try to dig up my old mpxf controller and take some pictures so you know what I'm talking about.
    Tidder
    Try RevFE
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    I use a small Back lit datalux keyboard thats in my visor then I have my mirror controles that are on my door control the up down right left of the keyboard and enter,when the switch is in the mid position and still control my mirrors. But I wouldent spend $50 bucks on a bare KB circit If you can spend $30 for a logitech and get the vol and track conroles off of it and intergrate them.Either way your gona be soidering something!!!
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by CHUPACABRA
    Why would you spend $30? I'd grab a cheap like $8 keyboard and use that. I do agree with you though, lots of soldering...
    Tidder
    Try RevFE
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    Quote Originally Posted by MajikNWA
    Majik
    I used one in my mame cabinet. Works great. No soldering, just strip wires, crimp connectors, connect to switch.
    TX5
    TX5 is offline
    Sydney
    Quote Originally Posted by Tidder
    Just ripped apart an old keyboard i had around and plugged it into and old computer and tryed to figure out what combos i need.
    is there a list of the pin combo and what key they are for?? it would save a LOT of arseing around
    Constant Bitrate mindscream's Avatar
    Jun 2004
    Memphis
    Quote Originally Posted by TX5
    You've just found out something I realized a long, long time ago. No keyboard manufacturers do their circuitry the same. I spent about a week tracing paths for a keyboard idea I had.
    But as for that information posted, I doubt it.
    Good luck to ye laddie...
    Mind Scream out
  1. laptop keyboard question
    By smonice in forum General Hardware Discussion
    Last Post: 08-28-2004, 01:10 AM
  2. Interesting keyboard question
    By ruflyf in forum General Hardware Discussion
    Last Post: 02-09-2004, 06:34 PM
  3. A question about mounting a flexible keyboard
    By Rudical in forum Input Devices
    Last Post: 08-05-2003, 10:54 PM
  4. keyboard mapping question
    By jtk in forum General Hardware Discussion
    Last Post: 03-14-2003, 06:56 PM
  5. Question about creating a custom keyboard
    By Micahb in forum General MP3Car Discussion
    Last Post: 08-24-2002, 07:33 PM
