Page 15 of 21 FirstFirst ... 56789101112131415161718192021 LastLast
Results 141 to 150 of 202
Thread: Cheap touchpads...
  1. #141
    Oct 2004
    Philly
    Quote Originally Posted by joelw23
    anyone willing to sell me one or two of their touchpads????
    Thanks,,,,
    i'm in milwaukee zip 53219...
    Still have a couple. E-mail me for details
  2. #142
    Jun 2004
    I will have 10 more pretty soon, I could possibly put the wires in the connector, test it, and send it out. I guess PM me
    12.1 kiosk (screen separated), 99 gtp
  3. #143
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Shreveport, LA
    Any one had trouble with it in thier carputer only?
    I have the original one. It's wired up and seems to work alright on my laptop and desktop, but it wont work on my carputer. Via epia M2 12000.\
    I tried the drivers posted previously, but I just got an error message.
    Is there some obscure setting I haven't been able to find to enable the ps2 port maybe?
    Thanks.
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
  4. #144
    Jun 2004
    Shreveport, LA
    Got it working! All I had to do was remove touchmon from windows startup and reboot. Windows then recognized my alps touchpad and allowed me to install the driver.
    Now if only I can get the touchscreen from freezes with BT or GPS in action.
    '03 Escape 4WD:
    -Transflective 8.4"
    -Slim Slot DVD+RW
    -RR, DFX 4
  5. #145
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Well, had successfully wired the first one today.
    I suck big time at soldering, and of course, I trashed 2 touchpadís trying. The twisty tie thing didnít work too, very random contacts. Give up and gave a few days to think things out.
    Today I was replacing an IDE drive and I found myself staring at the 80 conductorís flat cable.
    I just cut 10 conductors off the cable to fit the touchpad connector. I cut off the plastic isolation in one side of the ( now small ) flat cable till the copper was clearly visible and stuck that end to the connector. I separated the conductors on the other end and did a few continuity tests. I found several combinations off conductors/pins, but could get 5 of the pins. The Ground didnít work but thatís no problem since is very easy to get it from the touchpad itself.
    Then I just hot glued to the Touchpad and soldered the mouse cable. Works fine.
    I will confirm this tomorrow by making a few more and taking and posting some pics.
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  6. #146
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Jackso
    Ok, for those of you with THIS "goldmine" pad, the hookup is as follows...
    Pin 1 -- VCC - +5
    Pin 2 -- DATA
    Pin 3 -- CLK
    Pin 4 -- GND
    When I did it, I chopped a PS2 extender and used it to solder to, the wire colors on mine were as follows (note this is probably not true for all ps2)
    Black -- DATA
    Red -- GND
    Orange -- VCC - +5
    Yellow -- CLK
    Also, I've taken hcker2000 pic, and edited it to show where I connected each of my wires (hope he doesn't mind). Again I'll warn that it is a large pic.
    hope that helps someone
    When you say black cable, do you mean the thin black one or the thick black one? I've just gotten my goldmine one today
  7. #147
    Jun 2004
    Bravellir, you might have trouble with the hot glue coming loose. I tried superglue, and one of the wires lost contact. If you do another one, go with some sort of epoxy to be sure that it won't come undone. Good job getting it working though, its a pretty big pain.
  8. #148
    Feb 2004
    Green Bay, WI
    has anyone figured out how to wire it up with a usb cable??? I have a cut usb cable that i want to connect to the end of a ps2 cable....or if anyone knows the where to solder the usb cable directly to the touchpad.....
    this is what i want to do
    TOUCHPAD---->PS/2 Cable---->USB Cable---->USB Plug........
  9. #149
    Feb 2004
    Green Bay, WI
    i would like to do this without having to buy a usb to keyboard/mouse adapter
  10. #150
    Feb 2004
    Green Bay, WI
    Standard USB Cable Wiring Color Code
    5V / Red
    D+ / Green
    D - / White
    Ground / Black
  1. Cheap AM Radio
    By ukchris in forum General Hardware Discussion
    Last Post: 10-27-2004, 03:52 PM
  2. Help me choose CHEAP LCD please
    By Dr Jeckyl in forum LCD/Display
    Last Post: 04-13-2004, 01:27 AM
  3. cheap sproggy parts source needed
    By drwho in forum Power Supplies
    Last Post: 09-14-2003, 09:47 PM
  4. How about this for a cheap TFT?
    By LCDcrazy in forum LCD/Display
    Last Post: 08-09-2001, 07:09 PM
  5. cheap vid card w/ a tv out
    By donalson in forum General Hardware Discussion
    Last Post: 11-30-2000, 02:01 PM
