Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: Laptop Touchpad to PS2
  1. #31
    Low Bitrate suburbank2500's Avatar
    Jul 2006
    Norway
    Quote Originally Posted by lbergamo View Post
    Further review of the the touch pad PCB. The PCB looks to be shard with another chip I think handled the little "finger pointing device" recessed in the keyboard. This is complicating things for me. Below I have included some images of what I am dealing with.
    Top ( Left to right ): Touchpad PCB, Touchpad PCB with pins traced...
    Bottom ( Left ): Close up of the touchpad PCB with pins traced...
    plan to add custom buttons, as they are on a separate board and one button is defect. This buttons can be connected to T6, Left Mouse Button and T7, Right Mouse Button. 5V = not pressed, 0V = key pressed.
    Here is the Pinout for the Synaptics chip picture 2
    the ps2 is the male connector.
    its not tha same chip, but i guess the connections are the same..
    good luck
  2. #32
    Low Bitrate lbergamo's Avatar
    May 2009
    Michigan, USA
    I am sorry. Could you be a little more specific. I appreciate the help. How did you determine those test points ? Are they aligning with something or did you refrence something.
    You help is very appreciated!
    Thank You in advanced Leo
  3. #33
    Jul 2006
    Norway
    in this picture you se the edge marked "key". this is the corner of the chip with the round marking (dot).
    the numbers match the pins on the ps2 plug.
    i found this online.
    As i can see they match the colors you have in your pic.
    Just connect it to the ps2 plug and try.
  4. #34
    Jul 2006
    Norway
    her is the picture
  5. #35
    May 2009
    Michigan, USA
    Where and onto what do I exactly start to solder on ? The circular gold plated spots on the PCB marked with a T and a numeral ? If so wich ones ? In between post I was Google'ing for more specific info peratining to my touchpad to no avail.
  6. #36
    Jul 2006
    Norway
    do you have the flat ribbon cable for the touchpad?
    i guess its a 12 pin connector ?
  7. #37
    Jul 2006
    Norway
    look at this, i think this would work for you.
    Attached Files Attached Files
  8. #38
    May 2009
    Michigan, USA
    Again sorry to pester you. I think I can go from here. Just out of curiosity, where did you find the diagrams ?
  9. #39
    Jul 2006
    Norway
    Hi
    no problem at all
    Docs: http://www.synaptics.com/sites/defau...ies/ACF126.pdf
  1. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 10:52 PM
  2. FS: Infared Keyboard, PS2 touchpad mouse, USB FM transmitter
    By bondbond55 in forum Classified Archive
    Last Post: 09-02-2004, 12:05 AM
  3. Shutdown/Startup Controller for laptop
    By JoyRidun in forum General Hardware Discussion
    Last Post: 07-01-2004, 06:08 PM
  4. Replies: 11
    Last Post: 12-02-2003, 07:29 AM
  5. Wanted: touchpad & mini keyboard (ps2)
    By Alives in forum Classified Archive
    Last Post: 02-04-2002, 01:16 PM
