+ Reply to Thread
Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Laptop Touchpad to PS2
    Newbie Paddymcc's Avatar
    Ireland
    How can i convert a touchpad from an old broken laptop i had to a PS2 connector?
    the make of the touchpad is Synaptics model: TW1002M1
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Most likely it already IS PS/2. The trick then is figuring out what the pinout on it is, and make a connector.
    You should first see if you can find the info on the web. If you can't you might be able to figure out some pins, like power and ground, just by looking at the PCB, and simply try the data and clock in different combinations. That's what I did for a touchpad for which I couldn't find the pinout.
    Jun 2003
    Memphis - TN
    I have one thats PS2
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Ireland
    Ive managed to get the wire soldered to the touchpad flat cable. Tricky to say the least with a couple of burnt finger tips But im getting there slowly but surely.
    I still am unable to find a pin out diagram anywhere, even the synoptics site is no use.
    Dec 2003
    i want to do this as well. I found a tutorial on the web a while back. Cant seem to find it now. BUT, i was wondering, would we need specific drivers? Also how would we perform calibration and such?
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    there should be a driver available for the laptop that would suit the device if it was already PS2...
    -Mars
    Ireland
    Right i've checked my PS2 cable and it has the following wires attached
    (S2 Connection at back of Computer)
    ______________||____________
    White Blue Red Yellow Black
    +5 ? +5 ? -ve
    I also have five wires coming from my Touchpad, anyone have a notion how i would go about attaching these to the above connections?
    Aug 2004
    SE Michigan
    PS/2 has 6 pins. They are:
    1: data
    2: reserved
    3: ground
    4: +5V
    5: clock
    6: reserved
    Your device might use the reserved pins, but you can safely ignore them and it'll still work fine. That leaves you with 4 pins you have to connect.
    On the PC MB port, the pinout looks like:
    _6__|__5
    4_______3
    __2__1
    (sorry for the underscores, this blasted thing removes whitespace)
    Now, your problem is you don't know the pinout on your touchpad. If you can't find it, your only real recourse is trial and error. What I did was solder connectors on all of the pins, so I can try different combinations quickly.
    Some educated guessing can save you alot of trouble. Ground is probably the easiest to figure out by looking at the PCB, since many things tend to go to it. It's also the one you want to have right to make sure you don't damage anything - because the other pins operate at 5V, confusing them with power is probably ok, but who knows what reversing the voltage is going to do.
    Tred: you don't need specific drivers for PS/2, though some devices might have special features that require them. Even then, it'll work fine as a generic device with the OS's built in drivers.
    Dec 2003
    nice, im gonna mess around with this today...
    Low Bitrate F4kk3r0's Avatar
    Mar 2004
    Finland
    You may want to read this :D that's how I did It
    http://www.synaptics.com/decaf/utilities/ACF126.pdf
    I also had a sparepart laptop and I ripped the touchpad for better use, that ofcourse is to put it in my Nissan.
    LOL so the link takes you to interfacing guide.
+ Reply to Thread
  1. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 11:52 PM
  2. FS: Infared Keyboard, PS2 touchpad mouse, USB FM transmitter
    By bondbond55 in forum Classified Archive
    Last Post: 09-02-2004, 01:05 AM
  3. Shutdown/Startup Controller for laptop
    By JoyRidun in forum General Hardware Discussion
    Last Post: 07-01-2004, 07:08 PM
  4. Replies: 11
    Last Post: 12-02-2003, 08:29 AM
  5. Wanted: touchpad & mini keyboard (ps2)
    By Alives in forum Classified Archive
    Last Post: 02-04-2002, 02:16 PM
