animax and girder?
hello boy! there's anyone thant can solve my little bastard problem?
I made 2 animax IR receiver, 2 becouse I suspect that the first was bad
but the true problem is that, all works when I configure "Winlirc" to accept ir command by my remote control BUT when I shutdown the carputer AND shutdown the inverter at the new START of carputer the receiver won't capture any code! why?
if instead the carputer is shutdown but the inverter stay On (not normal use becouse the discharge of car battery) and then restarted it, the receiver works instead..
?!?! what the hell is the solution? I must shutdown the inverter! but if i shutdown it the remote wont work at reboot
noone that know a kind of solution?
here the links of the interface
http://ideegeniali.altervista.org/an...da/guida1.html
hey boy! no any other suggestion for remote controlling too??
I have just built that IR receiver, and also am going to just try the IR header on the motherboard. I dont' know when I will get a chance to play around with it again. I want the IR header one to work because I need both serial ports, but if doesn't, then I sacrific the serial port.
I can't think of a good reason for that to happen. I could possibly see it happening the way it does for you if it used USB. The serial port doesn't get power when the computer is off I don't think. If I get a chance to play around with it, I can see if the same thing happens to me. Maybe I can try the serial one I built on another computer, but I don't seem to have the time right now
thanx for post
now I'm going to try a usb to serial converter
I wanna try all the possibility solution
I hope in good
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
