Results 1 to 3 of 3
Thread: Lilliput touch overlay on different lcd.
    Variable Bitrate Bodgy's Avatar
    Nov 2003
    Briz Vegas, Australia
    Ok, a lot of people who buy lilliput lcds have no use for the touchscreen as they use them in projectors.
    Apparently the usb cable runs with the vga?
    Do you guys think it would be fairly easy to wire the overlay up to an individual usb extension? I plan on mounting it on a 7" composite.
    Cheers
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    Quote Originally Posted by Bodgy
    Cheers
    the usb cable and vga are combined into one cable (multiple cores) to save messing about you could use the existing cable, if not you would need to open a lilliput and find what wires connect to the usb plug on the far end of the cable
    remember the coluors may no follow the same all the way down best to use a continuety meter to check them first.
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
    Cheers
    Yes I do think it would be easy you just need to make sure you also get the controller for the overlay. There are only four leads off it. Check out this site should give enough to go on : http://www.tmz.com/wrx/lilliputLCD.html
  1. FS: NEW 10.4" LCD TOUCH SETUP
    By Motorcity in forum Classified Archive
    Last Post: 06-19-2004, 12:09 PM
  2. Bought 8.4" LCD Touch from eBay. HELP!
    By PaPP in forum LCD/Display
    Last Post: 05-31-2004, 01:28 PM
  3. Lilliput LCD monitors for UK customers
    By 001 in forum Classified Archive
    Last Post: 02-28-2004, 12:56 PM
  4. Replies: 5
    Last Post: 02-28-2004, 12:45 PM
  5. GROUP BUY: Lilliput TM-701VGT LCD
    By krystar in forum Classified Archive
    Last Post: 01-16-2004, 07:31 PM
