Results 1 to 10 of 13
Thread: looking for rear-view camera, need opinions
    Nov 2003
    Please let me first say sorry for asking a question often asked but i coulnd't find many topics that i think apply to me.
    I am very into car audio and in my SUV i plan on building a wall of subwoofers behind my head. I already have a 7" lilliput TS so i am going to get another lilliput screen (although non-TS). I need a good rear-view camera that will be mounted high on my Explorer's hatch. The reason my request is different from others is because I will have no use of my rear-view mirror. I will soley depend on the camera. I need a high quality camera that can view at a wide angle and of course be capable of seeing at decent quality at night. Mirroring capability is a must as well (so I can't make heads and tails of what i'm doing when trying to drive backwards). Hit me with what you've got. I promise to post pics of my ride with the rear-view installed once i get it!!
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    Nov 2003
    that one seems nice...although i'm not sure if the case will permit my application. I assume it is good for daily vision as well right? Cuz that is ultimately the most important (who can see well in their rear-view at night anyway). Looks good and a great price. I'm familiar with digitalww's site (that's where i purchased my lilli TS and where i am going to purchase my secondary screen). Any other recommendations!?
    Nov 2003
    bump, still looking for replies.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5725807610
    im thinking about getting one of those...
    Number of Pixels NTSC: 512 (H) * 492(V)
    Sync System Internal
    Image Sensor / Resolution: more than 380 TV lines
    Minimum Illumination 2 LUX
    S/N Ratio: More than 48dB
    Scan Frequency 60Hz
    Power Source: DC 12V/110mA (Tolerance: +/- 10%)
    Lens: 2.8mm / F2.0
    View Angle: 120° (120 degree)
    * (Dia) 24mm
    * (Dia) 15/16 inch
    Height (Tip to Tip of camera) 33.3mm or 1 5/16 inch
    Weight 65g (Net ) 75g (Gross )
    Picture Delay? Full Motion Real Time Color Video without delay
    view Displays a reversed camera image on the monitor to duplicate the normal view seen in a rear-view mirror
    Water resistant Yes
    Operating Temperature 14°F - 115°F (-10°C to 46°C) / RH 95% Max
    Storage Temperature -22°F - 140°F (-30°C to 60°C) / RH 95% Max
    TV System NTSC
    Casing Hard Metal Casing
    Mount Mounted Inside will fit into most vehicle key holes - no other installation needed
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Quote Originally Posted by WebDog
    Scan Frequency 60Hz
    Lens: 2.8mm / F2.0
    * (Dia) 24mm
    * (Dia) 15/16 inch
    Water resistant Yes
    TV System NTSC
    That's the exact same one that tbird2340 is purchasing - he provided a link in another recent thread about the same subject.
    -HD
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I just bought that exact one except from a different seller yesterday. I'm going to post a review when I get it.
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    I am still trying to determine if my plan would work (waiting on some feedback from others in the forum), but I want to use a Sony SuperHAD 1/3" low LUX camera as a backup camera. These would be the ideal solution since they are well regarded and have very good low light capabilities. The only problem is that the image would not be reversed.
    I am hoping the solution is going to be the mirror image function on some lilliputs. If they will flip the image in the x direction it would/should work. I am waiting for someone who has done this to post on how well it works and if there are some problems with it (such as having to reset it everytime you power the monitor on, etc.).
    "Protecting Privacy and Free Speech Online"
    http://www.eff.org/
    Dec 2004
    I remember that in my old setup, there was a wire you could pull high in order to reverse the image. Not sure if that would help, since your camera would most likely be on the entire time...
    May 2004
    AZ
    I had not thought of that, seems like an interesting option. I am really looking for a solution using the monitor to filp it since I am not sure that the Sony cameras support flipping the x-axis.
    http://www.eff.org/
  1. Rear view camera and dazzle usb
    By muldrick in forum Input Devices
    Last Post: 11-06-2004, 03:32 AM
  2. rear view camera
    By lasteclispe in forum LCD/Display
    Last Post: 10-21-2004, 11:00 AM
  3. Rear View Camera
    By 00GMC in forum General Hardware Discussion
    Last Post: 10-03-2004, 02:42 AM
  4. Rear camera view switcher (automatic)
    By M^ck^y in forum General Hardware Discussion
    Last Post: 09-07-2004, 06:40 AM
  5. Have video camera for rear view - which program?
    By nxt125 in forum Software & Software Development
    Last Post: 08-15-2002, 12:25 AM
