Page 2 of 45 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 449
Thread: M-Bus CD changer adapter for car pc integration
  1. #11
    Constant Bitrate lanman1's Avatar
    Dec 2004
    SC
    Sweet! What tasks need to be done to make this a reality? I'm sure many (myself included) would be more than happy to contribute.
    Ai-Net is my preference, btw.
    Keep us posted
  2. #12
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I want some how to use the CD changer (M-BUS) port for the aux input on my Alpine HU. There is no way (i know of ) doing it without a CD changer. Most newer M-bus HU has a mute line. Ground the mute line -> enable aux input thru changer port. This HU doesn't do that. It's an old M-bus HU (pre 95 model).
    jbor do you have any idea?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #13
    Constant Bitrate almera's Avatar
    Aug 2004
  4. #14
    FLAC jbors's Avatar
    Nov 2003
    My schematics not finished yet. I will release it all on mid Jan. It will be M-Bus, AI-NET USB adapter. Sorry don't want to mess up with serial. It will be available either as PCB+parts so you can solder it or as a finished product. Of course all the schematics will be available for public. I estimate the fully functional assembled device for ~39 by end of Jan. May be little cheaper...
    The link above is the good place to start but my schematics is different.
    Car pc integration with ease
    Car mediacenter
  5. #15
    FLAC jbors's Avatar
    Nov 2003
    Quote Originally Posted by MatrixPC
    I would recommend google:
    http://www.google.com/search?hl=en&l...er&btnG=Search
    If you don't want control over the PC from your HU it will fit you just right.
    Car mediacenter
  6. #16
    Sep 2003
    Beach City, Socal
    I bought an Alpine M-bus adapter (I think this is the model KCM-122B) from Crutchfield once and returned it because that adapter is not work with my HU.
    I search the net and the only solution I found what from one of the link from this site http://joerg.hohensohn.bei.t-online.de/mbus/, but I don't really understand the whole circuit.
    Searching this board there are some long old member stated that using a resistor (3.3K) may trick the HU to "think" that the changer is connected and thus enable the CDC port. I just don't know where to put the resistor.
    Some info I also found that the Honda/Acura HU also using the same Alpine M-bus for CDC and some stated that use 6V instead of 3.3K resistor. They just didn't stated that to which pin of the 8 pins (Data+, Data-, IGN/ACC, ...). Before I found solid information, I don't want to blew up the fantastic HU.
    Again, before the HU can talk to the CDC, the HU must "knows" that the CDC is connected. I need to know this part.
  7. #17
    FLAC jbors's Avatar
    Nov 2003
    In order to fool the HU you have to send the special sequence to it.
    Crutchfield has aux adapters that fools most of the M-Bus HU but not all.
    Joerg project does that fooling in PIC code. No PC involved.
    I prefer the PC solution as it is easily upgreadable. So it can tweak it if the default driver does not work.
    Car mediacenter
  8. #18
    Dec 2004
    SC
    Quote Originally Posted by jbors
    Sweet! Let us know what we can do to help.
  9. #19
    Sep 2003
    Beach City, Socal
    Dam.... back to square one.
    Thankanyway.
  10. #20
    FLAC jbors's Avatar
    Nov 2003
    Just let me know _exactly_ what you need. It would be much easier to answer that way. Probably I'm missing something.
    Car mediacenter
  1. External PC Card adapter for Verizon BroadbandAccess
    By Bluebisz in forum Wireless Communications
    Last Post: 02-24-2005, 10:11 AM
  2. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-26-2004, 12:21 AM
  3. cd changer hack
    By meyer64 in forum General Hardware Discussion
    Last Post: 08-25-2003, 01:01 AM
  4. Cig lighter adapter to power PC?
    By Alphared in forum General Hardware Discussion
    Last Post: 08-03-2003, 10:14 AM
