Results 1 to 5 of 5
Thread: replacing 8" Lilliput touchscreen
    Dec 2004
    The Great White Frozen North
    Hi;
    I've damaged my touchscreen panel. It occured after I absent-mindedly used the stylus to rub away some miniscule silicone streaks on the extreme edge of the touchscreen. As a result, if you run the stylus along the top edge of the screen, the cursor veers along the screen in tooth shaped pattern - down/up.
    I've tried to recalibrate both methods, but the panel is having none of it.
    In addition, I managed to inflate the plastic cover off the screen about 3/4 of an inch (the minicomputer I'm building is a sealed waterproof one, cooled by convection - not for in-car use!). I'd forgotten to install the pressure relief before leaving it on for a day as a temperature test, and the only relief was for expanding air to squeeze through the foam mounting tape between the plastic and touchscreen and the silicone seal. Piling a few books on it for a day squashed it back down, and it worked fine... until the silicone incident.
    Soooo... where do I get a replacement panel (don't need controller, just the glass bit)? Comments?
    CowPuter
    Dec 2004
    update
    Armen emailed me the answer... posted fyi.
    "You will need a panel from this kit: http://digitalww.com/8TSK.htm
    Currently they are out of stock but I will be getting some more ... Check back on the website and place your order when you see that the kit are IN STOCK.
    This is going to be the same panel as you have so it will be a direct replacement."
    Cowputer
    _
    Mar 2004
    Little Elm, Texas
    sweet!
    glad he could get you all taken care of!
    Jan Bennett
    Oct 2003
    Copenhagen, Denmark
    i broke mine even before i got it monted in the car, and got the TSK from digitalww as well, easy to replace worked like a charm.
    Jan
    Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Want to:
  1. 8" Lilliput Touchscreen Info
    By Mrbmw99 in forum LCD/Display
    Last Post: 12-13-2004, 02:31 PM
  2. Replies: 7
    Last Post: 11-19-2004, 12:32 PM
  3. Lilliput 8" Touchscreen
    By Jimbo1978 in forum LCD/Display
    Last Post: 08-30-2004, 10:11 AM
  4. 7" Lilliput for sale NO TOUCHSCREEN
    By CDesigns in forum Classified Archive
    Last Post: 05-24-2004, 10:47 PM
  5. Lilliput 8" Touchscreen Display
    By Randomtask in forum LCD/Display
    Last Post: 02-06-2004, 02:12 PM
