Results 1 to 10 of 10
Thread: Touchscreen and mouse?
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    Can I have a touchscreen USB connection and a trackball USB connection both opperating the mouse pointer on one computer at the same time?
    The idea being that I have a mouse or trackball up in the front seat in case the touchscreen fails or the button I need to press is too small or something.
    Will they both work at the same time?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    ....yes
    PC Components:
    My work log
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    You can always have more than one USB pointing devices.
    I use USB TS and USB finger/thump mouse/trackball thinggy without any problem.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2004
    Baltimore, Maryland
    Hella awesome
    Dec 2004
    Baltimore, Maryland
    I just bought USB extension cables to get my mouse and touchscreen from the front to the trunk. Now I'm hearing that the signal strength can degrade rapily in a USB cable. Do I need ot use some other device to ensure proper signal strength over about 15 feet? Or is that only important when you're using USB to carry data like to a printer or hard drive or something
    Low Bitrate BrUTaL's Avatar
    Dec 2003
    Guayaquil - Ecuador
    I have a USB active extension cable from my trunk to the front and I have connected a self powered USB Hub.
    http://www.cwol.com/usb/usb-active-e...able-uc600.htm
    So far everything is working fine for me. By the way, you can have the TS and mouse at the same time.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I've got over 15 feet with a self powered hub in the middle and it's working fine. If you're worried, hook all of the cables together and plug everything in on the bench and try it out.
    Want to:
    Dec 2004
    Baltimore, Maryland
    I'm going to have the mouse and touchscreen with two seperate 15 foot leads to the computer. No hub. No booster. Should they be fine?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    They should be. The USB spec says don't exceed 15 feet. Yours won't.
    Want to:
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Cables are more expensive than a hub. I would use one 15 foot cable with a usb hub on the end. Then you can always add more items such as a GPS.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  1. messed up touchscreen
    By chavoush in forum Input Devices
    Last Post: 07-10-2004, 10:54 PM
  2. Lilliput touchscreen problem
    By samc in forum Input Devices
    Last Post: 05-09-2004, 11:12 AM
  3. Replies: 2
    Last Post: 05-04-2004, 01:52 PM
  4. Looking for Gear Shift/Knob as a mouse
    By Refael Azi in forum Input Devices
    Last Post: 10-10-2003, 06:14 AM
  5. Integrate mouse into Pioneer touchscreen receiver?
    By rulouder22 in forum Input Devices
    Last Post: 10-01-2003, 11:38 AM
