Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: USB IR stick to COM port??
  1. #11
    Jan 2003
    Ruston, LA
    Quote Originally Posted by OdysseyPC
    You actually can, many IrDA devices are compatible with the 38-kbps ASK modulation used in TV remotes.
    ing provides many hits on controlling your PC via IRDA
    Few that I have seen.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #12
    Registered User kollitiri's Avatar
    Oct 2004
    Athens, GREECE
    frodobaggins is correct, you can't use an IrDA device for controling your pc, instead if the manufacturer is giving this ability with extra software (i don't any device with this capability). But in general if you search in the MSDN you will see that IrDA devices are only for data transfer and you can't use it for controlling.
    Michael
    Have a healthy and nice New Year!
  3. #13
    Oct 2004
    Athens, GREECE
    In windows 98 you could do an IrDA to control the pc, but since Win2k they change the way the Windows are handling this device.
    It is better to get an ATI Remote Wonder II remote control or something like this PC Control from www.easyhome.gr
    I was trying for many days to do an IrDA to work like a remote control, it cost me a lot of time (=money) instead of 50$ for a ready pc remote control!!!
    Michael
  4. #14
    Variable Bitrate vxcarpc's Avatar
    Jan 2005
    Melbourne, Australia
    I have a new question on the same topic. How would the USB reciever on one of these
    http://www.streamzap.com/
    be different to that of a USB IR stick? Would I somehow be able to use the Streamzap drivers to interface with my current usb IR stick and say a learning remote?
  5. #15
    Oct 2004
    UK
    Forget your current usb stick.
    Look on ebay for an InfraRed Recriever. Make sure it is not IRDA.
    If you are OK to have one in your serial port rather than USB, try google... they are incredibly easy to make yourself.
    For the actual virtual COM-Port, try www.ircomm2k.de (IrCOMM2k. Virtual Infrared COM Port for Windows 2000/XP)
    Hope this helps
  6. #16
    Feb 2005
    Solution for the main question
    Quote Originally Posted by vxcarpc
    Hello. I was woindering if anyone could help.
    I have my car pc running Windows XP on a Epia 800 Motherboard. I have a small USB IR device from which I would liek to use to control my pc with. I have been reading about it and most people say that once you install the USB device you can configure it to be setup as a COM port. When in install my USB device is add's a new section under my device manager called USB devices not universal serial bus. I am unable to configure anything about it. I believe somehow I can setup a USB to serial bridge so that I can setup the USB IR device to be recognized on a COM port so that all the frontend programs will find it. I know the RS232 serial IR's work fine but I want to use a USB controller.. Can anyone tell me how i can do this please or link me to some software that will do this.
    thank you.
    I THINK THIS MAY HELP YOU:
    http://www.stud.uni-hannover.de/~kis...OMM2k/English/
    Please let me know whatever result you get.
  7. #17
    Oct 2004
    South Carolina
    interesting stuff. I bought an IRDA dongle type thing for use with my cellphone to transfer pics and tones, etc. I'll see if I can find a way to use it with girder and a remote control.
    if you search for a LIRC IR Receiver, it's very easy to build ... you need to go to radio shack and buy a DB9 serial port + casing, a capacitor, resistor, and a voltage regulator, and an IR Eyeball... (i think that's it) it's real easy ... works with girder ... costs less than $10 ... though it does take up a serial port (and I'm not sure if you can use a serial to usb adapter with it..)
  8. #18
    Nov 2004
    South West
    Bit of a bump on an old thread here but I thought it might be better than starting a new one..
    I was using a infrared reciver to download data from a electrical tester to my laptop for viewing.
    The IR reciver had a rs232 (com) pulg on the end of a cable which I simply plugged into my laptop.
    When i got a new laptop it didn't have a com port so I used a pcicia to com card to plug it in and this worked ok.
    I now have another new laptop and (having lost the pcimcia card) I just bought a usb infrared adaptor because the laptops built-in ir port wasnt assigned a com port number.
    When i plugged in the usb/ir adaptor xp found it and installed it ok but it's just come up in wireless devices and still no com port number.
    Having looked I have got a IrDA device (Sitecom), If I found a 'normal' IR reciver would that get given a com number?
    Or, has anybody found a way to assign a com number to a IR reciver?
    I don't want to control anything, only recive data.
    The problem is, when I run the program I want to use it just askes me to chose a com port and unless I have one I can't run it.
    Cheers!
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
  1. IR serial port receiver - where to buy
    By toadster123 in forum Input Devices
    Last Post: 08-04-2004, 10:17 AM
  2. USB Port sharing
    By navig8r in forum Software & Software Development
    Last Post: 04-12-2004, 06:13 AM
  3. Replies: 16
    Last Post: 11-16-2003, 12:30 AM
  4. USB IR Reciever?
    By orangewhip in forum General Hardware Discussion
    Last Post: 07-19-2001, 07:25 PM
  5. Networking across USB port
    By sleddog4 in forum General Hardware Discussion
    Last Post: 12-02-1999, 02:15 AM
