Results 1 to 6 of 6
Thread: jvc CDC ports to PC
    Jan 2005
    jvc CDC ports to PC
    ok is if possible to use the jvc cdc port on my head unit to output to the pc and use it to control the PC?
    Nov 2004
    Cali
    Quote Originally Posted by yonu
    I've been searching for something similar for my stock audio in my VW, and as far as I know, there is no OEM product that does anything of the kind. For VW there is a product that does that and some more, but at this point of time only schematics of it exist, nothing is for sale.
    So if you will really want to do something of the kind, you will need to do some programming of your own.
    Jan 2005
    the progamming isn't the problem i just have no idea how to wire it or what kind of data the port transmits
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    how about for Clarion CeNET Control or for Alpine Ai-NET
    Jun 2004
    so you are saying it is possible, through jacking the AInet path, to use the headunit to control a carputer?
    Oct 2003
    Quote Originally Posted by powerslide
    true if someone can decode ( revese engineer ) the signals.
    you could use this to control the pc as if it was a changer or an xm-radio.
    in theroy you could get a return signal to the display such a track and
    title just like xm.
    this sould be able to be done with a PIC as long as someone can figure out the signals from the head unit.
  1. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 02:10 AM
  2. External PC Card adapter for Verizon BroadbandAccess
    By Bluebisz in forum Wireless Communications
    Last Post: 02-24-2005, 09:11 AM
  3. In progress car PC install.
    By Arathranar in forum Fabrication
    Last Post: 10-20-2004, 12:49 AM
  4. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 01:42 PM
  5. home pc problem
    By Mitokondria in forum Off Topic
    Last Post: 08-05-2003, 11:36 AM
