Page 4 of 9 FirstFirst 123456789 LastLast
Results 31 to 40 of 85
Thread: Griffin Powermate pics - let's see 'm guys!
  1. #31
    Feb 2005
    Madison, WI USA
    My ebrake handle isnt actually touching the powermate. Theres about 3-4 mm of clearance. I can rest my hand on top of the ebrake and rotate/click the powermate with ease. I removed the rubber on the bottom of the powermate, and mounted it using 3m mounting tape.
  2. #32
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    I'm almost done with fitting a holder for my powermate. I had planned to leave the top edge intact and mold the console around it, but now I'm going to just trim the edges flush, although that might look weird with two high and two low sections. But still better than the alternative.
    It's made entirely of ABS, and the inside is sized 2.25", slightly larger than the base, so the LED light will still be visible somewhat. I like that as a visual cue for master volume level. I also have an insert fabricated so the powermate will sit high, but the spacer can be flipped over, and the powermate will slip inside and be flush with the top of the holder if I don't want to use it, or have a mechanic play with it when I have my car worked on.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  3. #33
    May 2005
    Oshkosh, WI
    As promised..
  4. #34
    Mar 2005
    Pomona, CA
    ooooh looks good...But I've gotta counter it...
  5. #35
    May 2005
    Oshkosh, WI
    That's hot! Mine's a slap and stick hackjob compared to yours!
  6. #36
    Apr 2005
    Virginia
    How do you reach them with the e-brake handle like that? Long fingers I guess. . .
    Sivart321, it looks like you have a slimmer aftermarket handle to help with access? And is your powermate still in stock form underneath the console? Just curious if you simply glued it from underneath and then put the knob back on.
  7. #37
    moahdib's Avatar
    Jul 2000
    Here is mine enjoy!
    Matches perfectly with the blue interior of my car. THe knob even looks exactly the same as my stereo.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  8. #38
    Mar 2005
    Pomona, CA
    The placement is actually rather convinient, not long fingers needed. It is not as easy to push and spin as it was before, but I rarely did that anyhow. Pressing, and turning works just fine. I understand where you are coming from. I did not think it would work there either until I tried it out myself.
    As far as installing it, I drilled a 1.5" hole with a hole saw, pulled the knob off, stuck the powermate in from behind, put the knob back on. No glue was needed as the center console ends just behind the plastic panel and supports the back of the powermate just right. I had to remove the clear rubber bottom to make it fit, but had no need for it anyway.
  9. #39
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    Now i Just have to figure out why the powermate fails to work about 50% of the time. Sometimes when you boot it works, sometimes it doesnt. Plugging it back in doesnt work either. Anyone have a clue? it really peeves me off to have to reboot all the damn time.
    Ford XR6T blueprint 4.0 L twin cam turbo.
    Xenarc 7" touchscreen M10000 Audigy 2 NX
    ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
    Griffin Powermate Panasonic DVD-CDW
    Pioneer 5x7 Four way, 2x12 pioneer subz
    600watt 6chan USA audio AMP
  10. #40
    Mar 2005
    Pomona, CA
    Do you have the newest drivers? Is it plugged into a hub? Is the hub powered? The powermate requires alot of juice for it to work nicely. I would put it on its own USB cable if possible, with an active extension. Or put it on a hub, with the hub connected to power AND with an active extension cable. I have found non-active extensions do not work properly with most devices.
  1. Griffin PowerMate? Can't get it to work... help please!
    By coachreed in forum General Hardware Discussion
    Last Post: 08-25-2009, 10:20 PM
  2. griffin powermate controlling gps (dest 3)?
    By alanp in forum Input Devices
    Last Post: 01-24-2005, 04:21 PM
  3. FS: Griffin PowerMate USB
    By muldrick in forum Classified Archive
    Last Post: 01-21-2005, 10:15 PM
  4. Device Like Griffin PowerMate
    By TheLlama in forum Input Devices
    Last Post: 07-27-2004, 01:32 AM
  5. The Griffin Powermate
    By tejohnson in forum General Hardware Discussion
    Last Post: 02-21-2003, 05:48 AM
