Results 1 to 5 of 5
Thread: Anyone Tried Using the OnStar Mic for Voice Input?
    Nov 2004
    Just wondering if anyone has tried to wire the Onstar Mic into the computer for Voice Activation? Not sure how good it would work or not, but I was just wondering if it had been tried, since it is in quite a few cars now.
    I have one in my car, and Don't use the OnStar service, so I was thinking about maybe trying if it was thought that it would work good, or are these cheap mics?
    Thanks,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by bry21317
    Thanks,
    Bryan
    Been in the UK I am guessing thats a GMC car ? Its its any thing like my Vauxhall ( UK GMC ish ) the wiring should be simply enough to connect to. They place the mic for those with the car kits built in above the drivers head...if they dont its left there any way.
    Point is if you track it back you should find a connector there some where... and after all its going to be nothing more than a normal mic.
    Terran
    Variable Bitrate Leddy's Avatar
    Mar 2004
    Per the manual:
    Remove the overhead console. Refer to Console Replacement - Overhead in Interior Trim.
    Disconnect the microphone (2) connector from the jumper harness.
    Unclip the microphone bracket (1) from the overhead console.
    Disconnect the microphone 2-way connector (2) from the mating 2-way connector.
    Here's some help so GL, and I hold no guarantee of anything. If anything bad happens it's all you
    2001 Pontiac Grand Prix GTP Sedan (Sold)
    2007 Scion tC
    WhereIsMyGPS.net Online Tracker
    http://www.cardomain.com/id/leddy
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    I bought an OnStar mirror for my Mitsubishi. I have everything wired. The mic doesn't seem to be working though. I think it needs a higher bias then the mic on my on-board sound can supply. Does anyone know how I would inject a bias in to it?
    Jun 2006
    DuPont, WA
    I'm using the OnStar mic for voice input into my car pc. I just spliced the wires at 8 and 9 (gray and bare) and plugged them directly into my mic input on my mobo. Works great for both voice control and OnStar.
    RPM_VR4, if you are trying to use the OnStar mic without the OnStar module than you need to bias it. I tried biasing with a 1K resister to 9V and that worked fine. I also did a 1k/1k voltage divider to the 12V car supply and that worked, too. I don't know if there will be noise issues with using the car supply, though, so it may be prudent to use a voltage regulator.
  1. input for panasonic deck
    By dizzytest in forum General MP3Car Discussion
    Last Post: 08-24-2007, 03:47 PM
  2. Weird Mic Problem.. Help!
    By veetid in forum Car Audio
    Last Post: 09-30-2006, 07:05 PM
  3. OnStar GPS Interface
    By Harry5150 in forum GPS
    Last Post: 08-10-2005, 09:07 AM
  4. IBM T42: disable onboard speakers and microphone using port replicator II
    By WhiteRabbit in forum General Hardware Discussion
    Last Post: 11-18-2004, 04:52 AM
  5. What do you use for mic input?
    By Sensor in forum Input Devices
    Last Post: 09-12-2003, 10:36 AM
