ummmm. What version of girder?
I will check out when i get home.
You want to see something really weird? Open the case and see how much actually is in there.
hello all, i got the creative infra remote, with the credit card size remote and gigantic reciever like a flying saucer. i am having a problem trying to make it work with girder, does anyone out there use this remote and what did you do to make it work with girder. first of all i barely made it working under xp. now it works but when i use it on girder, the learn command when trying to map the key, it keeps on giving me an error "error com 1 hex=8" or something. when i suppress the errors, it gives out a code but they never work. anyone have a simpler tutorial with girder and this remote? what plugins to i need to put on girder? i just used the generic ir reciever plugin i think. any help is appreciated. thanks btw, i am trying to make this work with road runner. thanks again
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
92 Subaru Legacy Wagon
Epia MII12000 :D
Morex 80W
120G External HDD
16x2 Charater Display
Creative IR Remote
VIA Sereniti 2000 Mini ITX Case
7.2Ah SLA Tank
PCMCIA 802.11b
256DDR Ram
Diamonds are for girls- wise men follow the stars
Hehe. Not much in there at all. I chopped mine up and put a USB-serial thing on it, then crammed it into a tiny box with a stereo headphone jack for the remote IR cable.
wow that is really amazing, that is exactly the remote i have. is it better if you go usb? i got a keyspan remote before and i cant get it to work with girder so i sent it back, now i got this creative infra and i cant make it work too (frustrating), btw the version of girder is 3.3 i think or 3.4. did you make yours work? how do i do it? help thanks
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
In order to get my creative infra working with girder I needed a driver.
So here it is, enjoy!
Mobo= Epia V
Ram= 640mb
Ps= m1-atx
Screen= Lilly 7" ts
Hd= 40gig
case= 1/10 scale model of my car (04 Saturn Ion QC)
soundcard= soundblaster mp3+
GPS= Holux gm-210
I didn't use girder. Just wrote my own code because it was easy. I only have 1 com port which is used for OBD-II so had to go USB. It works exactly the same though. No difference, just easier to plug in. The overall cost is a little more though.
You may be able to test it with HyperTerminal, although it's probably going to show garbage. Set it to the right COM port and 2400 baud, then start pressing buttons. You should at least see something if it's working.
I have that same remote.
I hacked it up and ran the Rx into a Belkin Serial to USB converter.
I use my SB Audigy NX Series remote on this cause it works with this Rx and has more buttons. I have the same remote for my ZS Pro on my home pc.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
hey thanks for the help, the creative plugin did not work but the com port setting of baud=2400 was the missing answer. got road runner working a bit, i say a bit because i can only open the roadrunner gml file once. after i close girder, and try to open the road runner gml, it gives me an error "cannot open data file". can anyone tell me why i get this error and how can i fix it? thanks again
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
Sweet! I would never have tried that. I was going to run the Audigy 2 NX IR sensor up to where the others are, but it works! I tried a few other remotes. Just the creative ones work with it.Originally Posted by LESLIEx317537
I would think that girder has bugs and left the file open so it can't reopen it the next time. Does it work if you reboot?Originally Posted by mick0uziel
