looks like a floppy power connector ... on the left side underneat the IDE pins
so i just need to connect the power cable for floppy drive?
thank you
what are the jumpers for?
I am trying to set my dvd to the secondary device
My OLD carputer page
My NEW carPC
Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
jumpers should be labelled, i think i can see the letters but can't quite make them out.
M = master
S = slave (secondary if you want to call it that)
C = cable select (device works out what it is by where it's plugged in the cable, if it's plugged at the end of it's a master, if it's plugged in the middle it's a slave, and if it's plugged in the other end (which is further away from the middle) you've plugged it in wrong that's where the motherboard should be).
The jumpers are not labeled. There are only 4 pins, I am assuming that they might be CD connectors.
Is it true that the slimline drives with an adpater are not capable of having two devices on a single cable? Right now I am trying to use the dvd as a slave device to my boot disk.
My NEW carPC
Does anyone know the answer to this? I put a jumper across pin 1 & 2, 2 & 3, and 3 & 4 on Jumper 4, but the CD drive detected as a master even when on the slave port. I'd like to run this as a slave.
Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
I have the same problem. This is really poor for this site to sell these devices with ZERO documentation. I am very disappointed. Shipping was fast! This does no good If I cant get specs on the parts I paid for. Googling brought no luck in a manual. If anyone has help, please share it with us unknowing people.
