Results 1 to 10 of 13
Thread: Zippy vs. Winamp
    Nov 2003
    Florida
    Zippy vs. Winamp
    I installed a Zippy keyboard today and it ran through all the normal driver installs , just the normal windows ones and the keyboard lit up and worked perfectly. I turned the computer off and it came back on and it worked, and then I put it in hibernate and it worked fine.
    Then after that I opened Winamp to listen to music, and I went to type in a song, and the keyboard stopped responding, I opened up notepad and tried to type something and nothing worked. then i closed winamp, and it still didn't respond.
    So i closed winamp and shut down the computer and unplugged the key board, and then plugged it back in, and then turned the computer back on, and it worked again, until I opened winamp, then it stopped responding again.
    I've never seen this happen before with any of my other keyboards that i've used, just the zippy one. Anyone have any ideas, or know how to fix it? Thanks.
    -=Chevy CarPC=-
    ETA: When i get more time
    -Custom Fiberglass Case
    -Epia M-10000 Nehemiah 1Ghz
    -Sony CDRW-DVD Drive
    -Seagate 120mb Hardrive
    -Opus 90w Power Supply
    -Lilliput 7" LCD
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    I have no idea what a Zippy keyboard is, but the first thing I would try is doing the same thing on another computer and seeing if it happens.
    At least that way you can ascertain if it *is* actually the zippy keyboard or some conflict between it and some other driver on your Car PC.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Nov 2003
    Florida
    -=Chevy CarPC=-
    -Lilliput 7" LCD
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by alienjj
    Oh, I've seen those, I never thought they needed any drivers?
    Nov 2003
    Florida
    Update: I tried to use the on screen keyboard that comes with windows to try to enter a song, and the same thing happened. It didn't respond when I opened Winamp. I tried all the buttons on screen and none of them worked. So this means something really wierd is happening. I'm going to try another keyboard tommorow and see if it is the actual computer not the keyboard. Anything sound familiar to anyone?
    -=Chevy CarPC=-
    -Lilliput 7" LCD
    Nov 2003
    Florida
    anyone?
    -=Chevy CarPC=-
    -Lilliput 7" LCD
    Constant Bitrate gizak's Avatar
    Feb 2004
    Phoenix, AZ
    are you using a usb hub?? I've had my zippy become unresponsive due to being plugged into a usb hub, this would also explain the touchscreen input if that's plugged into the same hub.... now the question would be, is the winamp deal a coincidence? Hehe...
    -GiZak-
    Carputer Project: 98% Complete!! *tweakin'*
    Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
    Nov 2003
    Florida
    i've got it pluged directly to the computer.
    -=Chevy CarPC=-
    -Lilliput 7" LCD
    Jul 2004
    I've noticed that when one USB device misbehaves it often has an effect on others connected to my system. when I first installed my carputer my gps, touch screen and usb ethernet adapter would go on the fritz after a while for apperantly no reason. I ended up trying different combinations of driver versions and eventually I found a stable configuration. Also there is a legacy usb keyboard option in the bios. try switching that on and see if that works for you. mine is not completely cured but at worst my gps drops out everynow and then.
    Variable Bitrate heezer7's Avatar
    May 2004
    IL, USA
    I was going to say maybe try reinstalling winamp for kicks. Only takes 2 seconds to install. Weird problem though...
  1. WinAmp visualizations in Windows Media Player (almost working)
    By NoPistonPC in forum Software & Software Development
    Last Post: 08-21-2007, 07:11 AM
  2. EPIA video + Winamp standby problem
    By crisr in forum General Hardware Discussion
    Last Post: 08-25-2004, 07:16 PM
  3. Questions about MediaCar Winamp vs. External Winamp...
    By Urinemachine in forum MediaCar
    Last Post: 07-21-2004, 02:33 AM
  4. Winamp Problems
    By Axis_Inc636 in forum Software & Software Development
    Last Post: 05-12-2004, 12:16 PM
  5. WinAmp 3
    By Rob in forum Software & Software Development
    Last Post: 01-26-2002, 09:00 AM
