Results 1 to 7 of 7
Thread: Custom mouse
    Apr 2005
    Minnesota
    Custom mouse
    Ok, I want to build my own custom mouse out of an old ball-type mouse, and an analogue stick from a dual-shock ps2 controller. The problem is...how would this hook up? I have no experience with infrared emitters/recievers like those in a mouse, so I have no idea as to what kind of signal is being sent at that level. If any information on infrared emitters/recievers would be well appreciated.
    Yes, I know there are some "presenting" mice out there that are similar.
    Da_Kooz
    Low Bitrate Pepe's Avatar
    Jul 2003
    Kingston, Ontario, Canada
    Well, from what I know (anyone can correct me if I'm wrong), but IR receivers look for the change from low to high before outputing a pulse. If you look inside the mouse, you will see the toothed wheels that pass between IR emitters and receivers. When you move the mouse, the wheel turns, blocking and then allowing the light to reach the receiver. This is what gives the low and high signal. Because this is a pulse type signal caused by the constant movement of that wheel, you can't really turn a joystick into a mouse control without using some other sort of mechanism. You'd have to be constantly slapping the joystick to one side to keep the mouse arrow moving.
    99 Ford Ranger - Bagged and laying frame
    Current Carputer project:
    Done:
    Custom mounted 7" LCD w/ TSK in radio bezel
    Custom center console for relocated headunit
    Via Epia M10000
    GPS
    MP3
    OPUS PSU
    DVD
    Apr 2005
    Minnesota
    This much I already know, what I want to know, is what type of electrical signal is being carried to and away from those parts, sorry for not being clear.
    Da_Kooz
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    in addition to what pepe said, analog sticks generally use a potentiometer to measure deflection. Pushing or pulling on the stick changes the resistance in a signal line, and the deflection can be calculated from that.
    A mouse is generally a relative device (move X from the last position) and a joystick is an absolute device (move to X).
    Here is some info on joystick interfaces: http://www.epanorama.net/documents/j..._joystick.html
    Steering Wheel Controls
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    FLAC evandude's Avatar
    Mar 2005
    Maine
    you'd probably be better off just skipping the mouse altogether. you can find information on the protocols for serial and/or PS2 mice, and all you have to do is send the right data packets directly to the computer, rather than trying to fool the optical sensor circuitry into doing it for you. I have used a PIC to communicate on the PS2 bus, it's very simple once you get the timing routines set up and make a simple routine to read/write to the PS2 bus; then you can just send data packets with numbers corresponding to the X and Y directions, the larger the number the further the mouse moves with each packet (ie- faster motion, if you are sending packets continuously)
    check out http://www.computer-engineering.org/ for information on the PS/2 bus. or google if you want to use a serial mouse; I can only assume that faking a serial mouse would be even easier.
    Apr 2005
    Minnesota
    Thanks for the interesting reading, now i may go another way, however, I still want to know the specifics of the Input/Output electricity through a infrared emitter/reciever.
    Da_Kooz
    Maximum Bitrate DeltaFX's Avatar
    France
    An other solution is to wire the minijoystick to a game port, and use a prog to emulate mouse moves from a joystick.
  1. CUSTOM!! game controler - joystick mouse - frodo controls
    By xdjxklusivex in forum Hardware Development
    Last Post: 04-02-2005, 05:10 PM
  2. PS2 3 Button(Rotary Wheel) Mouse Properties?
    By nFiniteTuning in forum Input Devices
    Last Post: 03-12-2005, 09:43 PM
  3. Replies: 4
    Last Post: 02-15-2005, 07:13 AM
  4. Smallest Touch PAd Mouse... or Shuttle Mouse QUESTION!!!
    By Boozshey in forum General Hardware Discussion
    Last Post: 01-23-2005, 02:38 AM
  5. Looking for Gear Shift/Knob as a mouse
    By Refael Azi in forum Input Devices
    Last Post: 10-10-2003, 06:14 AM
