Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Custom touchpad with right/left buttons and thumbpad in armrest
    Newbie ErikArmbrust's Avatar
    Apr 2005
    Nebraska
    just did this yesterday. cut apart a miniature keyboard and took out the touchpad. Had to cut off the wiring to the kayboard. I cut out a square section of the control panel I had to make, under the thumbpad keyboard. Then I glued the touchpad board under that flush. Then I soldered two momentary switches (red and black mini) into the little right/left click controller board and put them into place next to the touchpad.
    Finished carputer:
    2000 Black Blazer
    Construction/ finished/ before
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    Slick! Keep us posted on the progress!!!!
    Progress: |##########| 99.99%
    - Tweaking and enjoying!!!! Never really done.....
    -= MachPuter Project =-
    -= MachPuter Project Worklog=-
    Apr 2005
    Nebraska
    The only thing else that I'd like to do is find some kind of like.... rubber coating stuff that I can put on the edge of the aluminum square I had to cut out... so it would look better... (without electrical tape - hahaha)... anyone know of anything I could use to coat those edges? (rubbery)
    Finished carputer:
    2000 Black Blazer
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    look at computer modder's websites they have some rubber edging material that people use around exhaust holes they cut for fans.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    http://www.frozencpu.com/scan/se=Win...nu_search.html
    you could also use small rubber tubing from the hardware store, cut a slit down the center and glue it in place.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Apr 2005
    Nebraska
    very cool. thank you.
    Finished carputer:
    2000 Black Blazer
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    I have some rubber edge trim that would be perfect. PayPal me $5 and a length and I'll send it to you USPS Priority.
    Nice work.
    Fabricator
    Apr 2005
    Nebraska
    that's alright, i already bought some from xoxide.com. thanks anyway
    Finished carputer:
    2000 Black Blazer
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    looks just like automotive door edging which is like $2 for 3 feet of it at pepboys
    PC Components:
    My work log
