Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 62
Thread: Well the AirClick is a real disappointment
  1. #31
    Feb 2006
    MCB v.60
    Someone found a bug. Here is v.60
    http://www.savefile.com/files/9456875
  2. #32
    Jan 2005
    did anyone try this wrapper thing, im at work and cant do it right now.
  3. #33
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Does it work with Frodo, or Winamp? Or both?
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  4. #34
    Feb 2006
    What does it work with
    It works with anything thats is the foreground window or an exe that you assign to it. It will set focus to that window then simulate keypress to that window.
  5. #35
    Jan 2002
    Long Island, NY
    That is very nice. I will have to try this.
    Another thing to buy now.
    Anyone else wanna be the tester to this persons undocumented exe?
  6. #36
    Jan 2005
    regarding airclick mapping with the wrapper
    I configured this wrapper this morning which took a while to figure out which controls would work under frodoplayer but I got it finally. I got the play button to do a pause/unpause(play) both the back and forward buttons play the next and song before the volume goes up and down. The only thing with the volume is if you press the volume up button once it will continue to go up until you press the volume up again to stop it. This is the one thing I would like to see changed, it kind of difficult to press the volume twice to increase it a little bit. To map all of the buttons just assign letters in the wrapper executable and then go into frodoplayer and settings 1 then key shorcuts1 and map everything to the cooresponding function, also i had to edit the frodo config .ini file to get the volume to increase and decrease at a decent level, at first it jump all the way up to 60% in a couple of seconds. Overall a good wrapper for frodo at least. Thanks
  7. #37
    Feb 2006
    MCB volume
    I wish I have some control over that. I PMed Krystar to make us a customized Plugin for MCB instead of using Winamp's. By default the Airclick winamp plugin presses the volume button 4-6 times with one click on the remote. I was hoping to solve this with a new Plugin from Krystar instead of fixing it in MCB which will make it a bit messy. Krystar probably haven't checked his mail in awhile maybe thats why he have not responded. Hopefully we get a customized Plugin (which should be fairly simple to modify from Winamps plugin) and I can get the "Hold Down for fast foward" to work. I kind of need that function for my Xvid player.
  8. #38
    May 2005
    have you tried using uICE? Do a google search for it, they have a trial download on the site.
    I have the creative labs credit card remote, which didnt work too well with the original software, but now works great with uICE.
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
  9. #39
    Jan 2002
    Long Island, NY
    Quote Originally Posted by Rocky388
    Are you using the creative credit card remotes receiver or with another IR receiver?
    I have a creative credit card remote left over cause i took the creative reciever out of the car and threw it out.
    I might post it for sale for like 5 buks shipped. haha
  10. #40
    May 2005
    Quote Originally Posted by LESLIEx317537
    I'm using the receiver the remote came with, but I took the insides out of the bulky casing. The circuit board only takes up about a fourth of the casing..the rest is just empty. Pretty stupid design if you ask me.
    The remote will work with other IR receivers I believe. If not, theres plans online to build a serial IR receiver.
    status: Totaled
  1. can't play real audio files
    By Wax Man in forum FrodoPlayer
    Last Post: 01-31-2005, 04:11 PM
  2. Real Time Car tracking now working!
    By Magpie in forum GPS
    Last Post: 10-27-2004, 04:08 AM
  3. Real Audio Playback?
    By jadz in forum Media Engine
    Last Post: 04-26-2004, 08:49 PM
  4. DIY 300w ATX 12DC power supply. for real.
    By SOBIL in forum Power Supplies
    Last Post: 12-02-2003, 11:01 AM
  5. Help with Real DOS, memory managers, and sound card drivers
    By bombboyer in forum Software & Software Development
    Last Post: 04-11-2003, 06:10 PM
