Results 1 to 5 of 5
Thread: touchscreen not working
    May 2005
    i have a tview, recently installed it. installed the driver for the touchscreen. it doesnt work for some reason. do i need to unplug the mouse for the t/s to work?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    No you don't need to unplug any other input device for the TS to work....
    do you have the sound notification from windows when you plug it??
    when you open the Touchkit/configure utility do you see the usb device in the active panel windows???
    possible fix:
    1.reinstall driver
    2.Check that the TS is geting power.
    3.open the housing and check that the usb cable is tight in to the TS controller conector.
    Ckect one by one and narrow the problem down
    good luck.
    thanatos
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    I've been having TS problems with my DWW-700M recently. Not the same unit, but it will just quit working. The best way I've found is to uninstall the device, uninstall the software, unplug the device, reboot, plug in the device, install the software/driver. This has been my formula for the POS TS until I get it replaced
    May 2005
    i checked all connections. everything is intact. i will uninstall and reinstall tomorrow. should i unconnect everything and then reconnect after installation?
    Nov 2004
    Quote Originally Posted by iHATEspeedbumps
    Yes.... just to be sure.
  1. BMW 540 Touchscreen Complete!
    By sajid753 in forum Show off your project
    Last Post: 04-23-2007, 05:52 AM
  2. Touchscreen not working
    By Ascension in forum LCD/Display
    Last Post: 06-01-2005, 12:14 PM
  3. Touchscreen problems with nlite and minlogon
    By Ascension in forum WinNT Based
    Last Post: 06-01-2005, 06:18 AM
  4. Replies: 1
    Last Post: 04-27-2005, 04:53 AM
  5. Lilliput touchscreen problem
    By samc in forum Input Devices
    Last Post: 05-09-2004, 12:12 PM
