Results 1 to 10 of 11
Thread: Power Mate Volume Control Install!
    Variable Bitrate fromplanetbob's Avatar
    Jan 2005
    Now this is probably the best thing I've ever done to a car! It's a Griffen PowerMate which is basically just a nice big volume knob off a stereo only this one is USB. Turn for volume, push to mute/unmute. It's right where I can reach it with my right hand. So simple! I love it! The only bad this is the darn things costs $50!!!
    Larger Version (1,059 KB)
    Larger Version (1,108 KB)
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    did you know that if you search for powermate at this very moment, it returns 308 results?
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by silencery
    Maybe he is showing off his install. Ya, he should have done it in the show off your project forum, but give him the benefit of the doubt, He is not a BRAND NEW NOOB.
    Jan 2005
    Well, it's not really showing off my ride, it's more showing off my control device. But I figure if I post to the wrong area, moderators will move it for me.
    As for it being posted a million times, this makes 1 million and 1. It's not like it's a bad thing.
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Now you need to fabricate a recess in your center console for it. That's what I'm working on, in almost the exact spot you have yours, so it will sit with the botton 1/3 recessed below the surface. Then it will stay where it's supposed to when on the road, the wire will be hidden, and it will look more integrated.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
    May 2005
    Woodstock, GA
    Ive got a powermate and I love it. Are you running it through a USB hub? many people around here have reported problems with powermates and hubs
    Is this where the witty comment goes?
    97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
    Jan 2005
    I'm running mine off a powered USB Hub. The hub I have runs off 5v so I ran 5v power from the computer to the hub along with the usb wire.
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    my powermate is run through a non powered usb hub, no problems here
    Signature: [==||========] 20% complete
    Mar 2004
    "Power is being supplied by an Optima Yellow Top Deep Cycle Battery which is connected to the car's main power by an 80Amp relay which engages when the car is on and disconnects when the car is off. This allows my carpc to run off the second battery while the car is turned off!"
    ..from your site.
    this is excelent solution! i will do the same thing!
    and now one question
    There arent problem when your using both powersuplies when car is off? enought power?
    Constant Bitrate Nobias's Avatar
    Apr 2003
    Ohio, USA
    Quote Originally Posted by fromplanetbob
    Amazon has it for 36.99 with Free Shipping right! Sounds like a pretty good buy to me....
    Powermate @ Amazon
    Status: 40%
    Car: 2006 Scion tC (Buying)
    CPU: AOpen Pandora/1.5 Cel M/1GB DDR2/Ipod Vid
    Screen: Lilliput 7"
    Power: Carnetix 1900
    GPS: Deluo GPS
    Software: nLiteXP, RR, IG, PhoCo
    XM: XM Direct
  1. Volume Control Solution, a good one too
    By clean customs in forum Input Devices
    Last Post: 01-26-2005, 09:40 PM
  2. FM Radio- VOlume controls- Mute line-in- control master
    By live2themaxuk in forum FrodoPlayer
    Last Post: 11-16-2004, 02:33 AM
  3. Replies: 13
    Last Post: 11-15-2004, 12:42 AM
  4. Power control with tank
    By 4u2n in forum Power Supplies
    Last Post: 10-24-2004, 04:41 AM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
