Results 1 to 4 of 4
Thread: Serial->PS/2 touchpad dont work after hibernation
    May 2003
    I have a serial Fellowes Internet Touchpad that is used through a serial to PS/2 adapter on my truckPC. But everytime i come out of hibernation, the touchpad doesnt work anymore. It only works after a restart. Does anyone know what could be the problem?
    I have a Delorme usb GPS that is using the serial emulations driver thingy (whatever you call that driver) if this helps you help me. Thanks
    May 2005
    orange county, ca
    could be a conflicting driver on your system, make sure you have correct/current driver installed for your touchpad, and if you have any other mouse or touchpad drivers uninstall them.
    I had the same problem with a laptop touchpad, and the problem ended up being i had additional mouse drivers installed that were conflicting somehow. after I uninstalled them, my touchpad started working after resuming from hibernation.
    FLAC evandude's Avatar
    Mar 2005
    it might be due to the PS/2 system itself. I have done some work with PS/2 devices on a hardware level... PS/2 mice are not designed to function without being initialized by the system, and it's not really set up so that the computer can realize when a mouse is plugged in. so sometimes if you plug in a PS/2 mouse while the computer is running, it will work, and sometimes it won't. (and if you restart, it gets initialized again, and works fine) I had a project where i was interfacing with a PS/2 mouse and I found that if i connected the mouse AFTER powering up the board (initialization sequence already took place) then it wouldn't work. if you can't solve the problem by messing with drivers, then perhaps you should look into a USB device instead, because PS/2 really isn't that robust.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    May 2003
    This worked fine before i had to reformat the PC though....some kind of driver issue.
  1. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 01:53 PM
  2. Replies: 1
    Last Post: 10-02-2004, 01:27 PM
  3. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 11:49 AM
  4. XP hibernation doesn't work
    By nicgalla in forum Software & Software Development
    Last Post: 08-03-2003, 09:18 AM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 08:48 PM
