Results 1 to 10 of 10
Thread: How Do I power My Rear View Camera
    Jan 2005
    I have a rear view camera and I know exactly where I want to put it but I am unsure as to how to give it the power that it requires. Can anyone put me in the right direction for information?
    J
    EDIT: It looks just like the one in this photo. It has a video RCA connector and a power connector. I though I saw awiring kit that could be purchased that would adapt it to a car power supply.
    Any help is greatly appreciated.
    Low Bitrate Shotty's Avatar
    Jan 2005
    Brisbane, Australia
    Umm... what kind of camera is it?
    If it is just USB powered, then just run a long USB cable.
    Otherwise we would need to know more specific information.
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Power it from your computers power supply
    Jun 2005
    London, UK
    surely it's better to run it directly off the battery so you save your precioius watts (and won't need a big PSU)
    Nov 2004
    You can tap into your reverse lights like this guy did.
    http://www.rx8club.com/showthread.php?t=62547&page=1
    I wanted to be able to switch to the camera during driving also so I'll probably be tapping into the cigarette lighter for the rear seats. I also have an rx8 and not sure if I want to grind down the camera to make it fit... where are you placing the camera? I also bought the same camera he listed that was on sale on ebay. Good luck!!!
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    Should work with any 12V source
    Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
    Trunk fiberglassing in progress...
    Need GPS / Aux Input / WiFi
    My Corolla Computer
    Constant Bitrate CornToeGoblin's Avatar
    Dec 2004
    Texas
    it depends on the voltage of the camera, post some specs of the camera in question
    2008 Civic... Sound system... then carputer install...
    WORK IN PROGRESS
    If you look at my avatar closely, you can see a chick with two big knockers....
    Constant Bitrate craniumdesigns's Avatar
    Apr 2005
    Hayward, CA
    i believe its 12v/110ma
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Shreveport, LA
    In short, I powered mine of the 12v constant line, but I have an intrucate maze of relays and switches which power it on or off.
    My backup lights have two leads, obviously. They're both ground when the car is turned off and 12v high with the acc bus. When I back up, one of those leads drops back to ground. So the difference between the two relay the 12volt constant back to one input of a three way switch in my center console. The three way switch has this auto-mode, no connection, & 12volt constant as inputs. The output goes to the back of the car where it relays 12volt constant to the camera. There's probably an extra relay or two in this system, but I wired it this way so that my wire runnning from the tail-lights to the center console carries almost no current. (it only drives the relays on either end)
    I also have a Cheesebox set up so that anytime the camera is powered, the composite video signal overrides the VGA computer signal.
    In the end, I've got a three way swith with on, off, and auto, and the power ultimately comes from my rear cigarette lighter line.
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Powered mine through my taillights,
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  1. Whats wrong with a webcam as a rear view camera??
    By bankingdom in forum General Hardware Discussion
    Last Post: 04-06-2013, 04:13 PM
  2. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  3. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:14 PM
  4. Replies: 2
    Last Post: 09-21-2002, 10:48 PM
  5. Have video camera for rear view - which program?
    By nxt125 in forum Software & Software Development
    Last Post: 08-15-2002, 12:25 AM
