what kind of connection does the irman use (serial, usb) ?
Is there any way to hack into the IRman and just take out the infrared reciever and mount it into my dash? The box it is is it way to bix. I kinda want just like a little hole for my infrared to work with Girder....If not are there any other IR receivers that are tiny like pin holes?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Serial
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
I tried taking it apart and soldering wires to the ir reciever. Turned out to be a big pain in the *** and it didn't work in the end. I'm sure its doable by someone with better skills than I
Alex
90 300zx twinturbo conversion
Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
