Results 1 to 7 of 7
Thread: windows roll up
    Constant Bitrate i3igmind's Avatar
    Mar 2005
    Lightbulb windows roll up
    Hi,
    I want to see if anyone b4 thought of doing this with switches and relays? Or if someone has a digram of how to make the windows roll up when u arm you car.?
    thanks in advance
    HOnda Accord '94
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by i3igmind
    Hi,
    thanks in advance
    It's called full/total closure, my alarm already does it
    Mar 2005
    i want to build it
    well not all people have ur alarm
    but good for u,.
    the point it will feel a lot diffrent if i build it my self
    HOnda Accord '94
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK, well let's start with the basics
    1. Do you have electric windows?
    2. does the car offer the facility to do the total closure with the key (mine did before I put the alarm in, that made it easier for the alarm to do it)
    3. if 1=yes and 2=no do you windows go up and down automatically or do you have to hold the button for them to move?
    Mar 2005
    re:
    yes i have an electric windows, and i have to hold it up to close it , but i can just push once and it goes down.
    what i want to do is when i arm my alarm the signal will check if the window is open or no, if it's open then it'll triger a relay. if it's not open then it'll do nothing.
    HOnda Accord '94
    Low Bitrate tarpitblue's Avatar
    May 2005
    Tampa, FL
    this is all you need
    http://cgi.ebay.com/VIPER-CLIFFORD-C...QQcmdZViewItem
    set the timer for 5 secs or however long it would take to roll up a window and set it. you could use just one but i think i would use it with 2 or 4 regular relays (1 per window). just use the power of the door lock wire that activates (either + or -).
  1. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 02-11-2011, 02:14 PM
  2. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  3. roll down my windows!!!
    By CArringt in forum MacCar
    Last Post: 05-03-2005, 03:50 PM
  4. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  5. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
