Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: DWW-700M Touchscreen gone be crazy
    Apr 2005
    France
    Hello All,
    I've got troubles with the touchscreen of my DWW-700M . It works fine until a short time and after the cursor goes anywhere or sound blocked on axis.. vertical or horizontal....
    I'm using Worcol driver...with this software there Draw section to test the calibrating. it can show me the troubles very fine. if i design a square the line don't follow the finger or pen.
    What s wrong with it ??? have you already seem it before ?
    AIR-V
    Newbie patz's Avatar
    May 2005
    Canada
    Angry same prob
    same prob
    send back to Armen..
    I got new one..
    work great for 1 month
    now.. it's fu*ked again
    i don't want to send back another time.. because:
    1- i'm from canada... (43$ for shipping)
    2- with my second DWW-700M.. motor seem to be better (more power..less noise) than the first one.. i don't want to take a chance to have poor motor..
    3- summer=driving
    4- receive two dww-700m... got 2 defect unit .. "never 2 without 3"
    search in forum .. fews people got same prob..
    and check this thread:
    Touchscreen defect ?
    good luck with your DWW-700M
    May 2005
    Canada
    you're not alone
    Constant Bitrate mugu's Avatar
    Oct 2003
    San Antonio, TX
    I have the same problem as:
    Problem is with the drivers methinks.
    Tried the drivers supplied, and all drivers on egalax.
    Egalax supplied drivers works perfectly on my mac (OSX 10.4).
    <edit>I was wrong, the powerbook looses calibration after a few minutes in the same places the pc does</edit>
    Been scouring forums, havent found a real fix with this.
    Tried all combiations of drivers with fresh install, sp1, and sp2.
    I get it working for about 10 minutes, then it will go back crazy..
    Any definitive fix before I rma my entire setup?
    May 2005
    Canada
    my prob it's not because drivers...
    when i receive my new dww-700m (the second one) .. i don't installed new drivers.. i just plug in usb .. and use driver used with my first defect screen ... (egalax 4.0)
    the screen work perfectly .... during the first month.. after that.. some area of LCD stop to respond...
    begin with the bottom right corner (square of 1/8 inch)
    fews days later... (square of 1/4 inch)
    fews days later... (square of 1/2 inch)
    fews days later... bottom left & top right corner too...
    my carputer is 100% finished .. so no new hardware .. except last week I plug usb mouse because my touchscreen don't work anymore..
    after calibration (25).. work better.. except bottom right corner.. and I need to re-calibrated each 10 minute
    sometime mouse pointer stay in top left corner.. don't want to move anywhere.. but i can click at (0,0) position .. woohoo..
    sometime.. when i press somewhere and the mouse cursor don't move where i want to ... i can apply a stronger pressure.. sometime work.. sometime not..
    i think some area of my LCD is frozen ..
    my workaround: draw a LARGE SQUARE .. before trying to use touchscreen.. repeat this each 10 minute .. and before calibration..
    Jan 2004
    looks like a real bad problem, i say try to refund and get your money back
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    This problem also has a fix. If you bought your monitor from me you can return it for repair. It needs a new touch panel. For those that want to do this yourself, I can send you a new touch panel. Here is a how to: http://www.digitalww.com/DWW700M_touchpanel.html
    Armen
    Oct 2003
    San Antonio, TX
    Wonder if ziplock will provide the same courtesy, heh heh.
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    Armen is very helpful with everything he sells, and backs it 100%. I hope you all get your problems sorted out, he made sure I got mine sorted out very fast.
    300th post
    xtn
    xtn is offline
    Jan 2005
    i live in the UK and got one from here, same problem. can't send it back cause it would cost about $150 (&#163;70) and couple of weeks with a hole in my MG dash.. the whole thing sucks if you ask me....
  1. DWW - 700M : not opening
    By John_Duh in forum LCD/Display
    Last Post: 05-30-2009, 11:04 PM
  2. Replies: 3
    Last Post: 07-11-2005, 06:23 PM
  3. Touchscreen problems with nlite and minlogon
    By Ascension in forum WinNT Based
    Last Post: 06-01-2005, 06:18 AM
  4. Replies: 4
    Last Post: 10-13-2004, 10:17 AM
  5. 7" Lilliput for sale NO TOUCHSCREEN
    By CDesigns in forum Classified Archive
    Last Post: 05-24-2004, 10:47 PM
