Results 1 to 6 of 6
Thread: Gyration mouse/keyboard interference?
    Constant Bitrate OoNikFraleyoO's Avatar
    Mar 2005
    Alabama
    Sorry if this a repost, but I couldn't find anything on it. My mouse and keyboard work fine in the house. When I take them to the car however, they will work fine for a while, then start working intermittently, then stop working all together. It seems like the receiver "forgets" the mouse and keyboard. While in the car, it won't "learn" them most of the time (every now and then it will after trying for 10-15 minutes) but in the house, everything works just fine. I'm not using a hub. I was wondering if anyone else had experianced this and if anyone had any suggestions.
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    my prob was the location of the antenna for my gyration. I use the mini kb gyration. In the house it has a range of around 25ft. in the car, about 2ft. This is what I did to get mine working.
    1. get the gyration working with the car OFF, not running.
    2. now get it working with the car ON, running.
    From there you can move the gyration antenna around in the car, with the car running, since you got it working with the car off. You can find out where it will work and where it will not work.
    I have been using the gyration kb (not the mouse cause i use the xenarc TS), for well over a year now with no problems.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Mar 2005
    Alabama
    Well, its not a problem of range, cause I've tried them within inches of each other. I Think I may get a USB extension and move the reciever to the front of the Jeep away from my amps and the W7 that I'm almost positive is causing the problem.
    Mar 2004
    Fort Myers, Fl
    also check your services in XP. The HID Input Service needs to be on automatic. I have found that with that service turned off the gyration will not work.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Feb 2004
    North Aurora, IL
    i have the same issue.. but its only with the keyboard.. the mouse works even when the keyboard stops.
    I wish i knew how to do fiberglass work...
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I rarely use they keyboard and find now every time I want tuse I have to relearn it. Didn't have to fo r the first year I had it. But then I use it even less now than I did before.
  1. Weird video interference problem! HELP!
    By lookinco in forum LCD/Display
    Last Post: 03-18-2011, 07:10 PM
  2. FAQ: EMI / RF Interference
    By aoLhaTer in forum The FAQ Emporium
    Last Post: 02-05-2008, 12:44 PM
  3. Odd Interference Lines...
    By Tranman in forum LCD/Display
    Last Post: 07-11-2005, 09:05 PM
  4. Screen interference - grounding?
    By dmurray14 in forum LCD/Display
    Last Post: 05-26-2005, 08:56 AM
  5. digital voltmeter = interference??
    By owibitmytongue in forum General Hardware Discussion
    Last Post: 09-01-2004, 08:26 PM
