Results 1 to 9 of 9
Thread: How to calibrate in 800X600
    Constant Bitrate ashbosh's Avatar
    Mar 2004
    How do people calibrate in 800X600 resolution since the bottom 120 pixels get cut off?
    Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
    Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
    Holux G210
    03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    change refresh rate to 75hz.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Mar 2004
    I'm sorry, let rephrase my question. How to calibrate the touchscreen in 800X600 mode when the bottom part get cut off?? thx
    Holux G210
    May 2005
    Vienna, VA
    ashbosh, you can't. I tried that before. Asked several Xenarc tech support guys, too. There's nothing you can do.
    Nov 2004
    Did you try the 75hz refresch rate...???
    I run 800x600 75hz in my xenarc and the lower part shows just fine.
    Nissan Aux-in MOD
    Mar 2004
    I did it and it worked... THNAKS A LOT. Amazing or should I say weird??? It reduces the display height, for higher refresh rates, do you know why?? I like to know.
    Holux G210
    May 2005
    Derbyshire, UK
    Mine runs in 800x600 at 75hz too. I assume the lower refresh rates just don't get locked onto properly for it to resize the display to the correct aspect ratio...
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
    Mar 2004
    Thanks all for the help, especially thanatos106. Otherwise I was going to buy a new video card and agp riser card and run powerstrip and all. Saved me some $$, time(=$$) and headache and wife beating me up for spending too much time on it. :-|)
    Holux G210
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    Quote Originally Posted by ashbosh
    In the Touch config program you set the screen as a "split screen", and you tell the ts just to work with the upper shown 800x480 pixels.
  1. Xenarc locked in 800x480! Want 800x600
    By aoLhaTer in forum LCD/Display
    Last Post: 02-18-2005, 09:44 PM
  2. Replies: 1
    Last Post: 11-13-2004, 10:35 AM
  3. Probl. embedding FrodoDVD with 800x600
    By swissRv in forum MediaCar
    Last Post: 09-14-2004, 05:39 AM
  4. "Stretched" 800x600 MediaCar F-CNS skin available
    By febsperanza in forum MediaCar
    Last Post: 06-08-2004, 01:56 AM
  5. Replies: 0
    Last Post: 12-10-2003, 05:37 AM
