Hi.
I know that many are concerned about using a touch screen while driving
becase they have too look at the screen while operating it due to its
smooth surface.
It exists some quite thick tape-like strips which is from about 1 mm wide to about 1 cm wide with smooth edges. If you are mainly using a single software while driving, it is possible to
use this kind of "tape" to make a grid patern on the screen surrounding the on-screen buttons.
I dont know how well it works, I havent tried it first hand, but I have seen it in use, and the owner said he was happy with how it felt, and that after a while, it was easy to distinguish the different on-screen buttons with this method.
Just a tip..
Here is another tip don't pick your nose while driving at night
Serious i was driving past and cause the guys LCD screen was on his face was light up and he was picking his nose lol
normally you can't see the persons face when driving by but with the screen on you dojust a small tip hehe
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Placing the most-frequently-used buttons at the corners of the screen would make it possible to find them by feel.
wear a rubber, dude.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
Advice for the nose picker, don't touch the screen afterwards or else you won't even see the buttons.
Don't be a pilot between drivers, just a faster driver in a plane!!
I don't know about you guys but I know my carputer very well. I can navigate without even looking at the screen
