Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 60
Thread: MMI style rotary encoder install - details
  1. #31
    May 2004
    UK
    @henry
    What version of girder have you got?
  2. #32
    Low Bitrate Henry Winx's Avatar
    May 2003
    Derbyshire/Cirencester UK
    @ tony 3.3
    I tried quickly to find a turorial of some sort but had no luck, will try again when I have a little more time...
    EPIA M10000, Kingston 256MB, 40G 2.5" HDD, 40G 3.5" HDD, LG slim CD/DVD,
    Customised Cubid 2699R, Xenarc 7" moulded in dash, Opus 90w, bu-303
  3. #33
    May 2004
    UK
    @Henry
    You have a PM (only because its off topic for the thread)
  4. #34
    May 2004
    UK
    Scouse Monkey
    Have you got one of these new switched ALPs encoders?
    If so I would be interested in knowing how you get them here in good old blighty.
    Tony
  5. #35
    Aug 2005
    sorry
  6. #36
    Nov 2004
    Personally, I think that having a large wheel almost like a scroll wheel sticking out on the side of the monitor would be very slick. It could have some heft to it so there would be a bit of inertia too. It would be very much like paging through a book for scrolling through songs.
  7. #37
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    where heft == Griffin's Powermate?
    many are trying to get away from that much heft... but I get your point and agree w/ it on some levels.
    I've seen some larger (like the Powermate) knobs that can slide(not tilt like joystick) in 4 directions... rotate and momentary push(click).. now, if it had detents, THAT would be pretty nifty for ye'ol' ∙CarPC
    •Micke
  8. #38
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    What about instead of hooking up to a mouses scroll wheel hook it up to a keyboard encoder rigged to send keystrokes. This would give a lot more flexibility and more possibilities for customization
    The keystrokes could then just correspond to whatever hotkeys are used in your frontend program or generic keys used for up/down scrolling
  9. #39
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Hey, I've started doing something very similar in my Audi, aslo.
    Here's what I have so far:
    Removed Rear Center Console:
    The rotary knob/selector and 4 soft buttons will be located down from the cigarette ligher.
    Space Underneath the Console:
    Notice how much empty space is found down there...
    Sketch of what I want to achieve:
    The rotary knob/selector will be made out of another cigarette lighter (hopefully identical to the one I've got in the car).
    It will be mounted in the original socket and backlit by the LED I took out of the mouse (hopefully 1 is enough).
    The socket's negative terminal will serve as a mounting point for the PCB.
    The PBC will hold the Generic Mouse Encoder (if I find it to be too fragile, or brake it during installation, I will opt for a different, more durable encoder).
    The PBC will also hold a switch that will be wired to the mouse's SWM (middle click switch), which will make the knob work also as a selector/soft button when pressed upon. NOTE: Since the cigarette lighter has a built it spring, there shouldn't be a problem getting it back to Open Position.
    There will be 4 soft buttons positioned in the way I illustrated above. They will be primarily used for Play/Pause, Stop, Next, Previous (Clockwise from the top left). The reason I'm allowed to use 4 more buttons is because I came across a 5-button mouse.
    Mouse:
    I de-soldered all of the switches and soldered PS2 connecter into the board so I could easily un-plug and re-plug the device, if needed.
    Notice the extra two buttons to the left of the mouse.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  10. #40
    May 2004
    UK
    @tuckie
    Interesting idea. If the monitor is in each, its worth a try. For me, the monitor wasn't. I think I have seen some early HP laptops with your suggestion.
    @DJiK
    As you know, thats the same gearbox console as in my coupe. Your idea re: using the lighter is very stealth. If the mouse encoder isn't man enough its easy to wire in a bigger encoder. As you said, there is plenty of space underneath for the mouse PCB (I put mine in a small ABS box) Keep us posted with updates!
