Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 60
Thread: MMI style rotary encoder install - details
  1. #41
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    @Tony (and everyone else):
    I just came back from the junkyard and picked up a 12V Cigarette Lighter and Socket from a Mitsubishi Eclipse. It looks a bit different, but has the same kind of clear disc around it, and a good place for the backlighting LED.
    I'll start working on it in a few hours... Hoping to get it done by the end of Monday.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  2. #42
    Apr 2005
    Hey Tony,
    What did you use to make the three "Soft Buttons?"
    The ones with the little white dot in the center.
    I noticed they're backlit also... How?
  3. #43
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Quote Originally Posted by Scouse Monkey
    we are working on an 8 way joystick with rotation and push down but it is a few months away. I would copy Tonys for now. We are doing a full usb one without hacked parts.
    Why not use a Grayhill 60A joystick?
  4. #44
    May 2004
    UK
    Hi DJiK
    I used 3 * ITT red illuminated tactile switches. I bought them from RS in the UK - heres the link:
    http://rswww.com/cgi-bin/bv/rswww/su...o?cacheID=ukie
    As you may see from the picture, the holes for the switches are beveled using a triangular grinding stone attachment and polished. The switches are then mounted from underneath.
    As a matter of interest, where have you put your PC in your Audi?
    Tony
  5. #45
    Apr 2005
    Tony, the link above didn't work, but I found them regardless:
    They're a bit pricey though... 3.11 each.
    That's roughly $22 for all four... More expensive than a mini keyboard.
    I'm done with all 4 buttons, the encoder, and the actual mouse's bones. I just have to solder another connector or two and mount everything in the right place.
    Pics will follow shortly. (give me 48 hours)
    Oh, my CarPC is currently "mounted" in the trunk next to the subwoofer box.
    It's acctually held in place using a bunjee cord; nothing fancy.
    The carputer I'm using is a working version of the one from my sig "MiniPC Case."
    Eventually I will write a nice digest in the "Show Off Your Project" page...
  6. #46
    Mar 2004
    anyone selling a fully done one?
  7. #47
    Apr 2005
    Hardware Stage Complete
    Hello People,
    I'm done with the hardware stage.
    All 4 buttons, the encoder, and the Selector switch are working fine.
    Here's the pic:
    Up Next:
    Programming Girder (already started)
    Mounting it in place
    Lighting it up.
    Post your questions below...
  8. #48
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    how about a detailed writeup with instuctions and parts.
    Thanks.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  9. #49
    Apr 2005
    Quote Originally Posted by Quattro
    Thanks.
    Look in Post #39... I've pretty much followed exactly what I orignally had planned.
    All of the juicy details will be in the digest once I have it working in the car.
  10. #50
    Mar 2006
    problems
    hi many can you tell me how many K is the enconder?
