Page 6 of 6 FirstFirst 123456
Results 51 to 60 of 60
Thread: MMI style rotary encoder install - details
  1. #51
    Mar 2006
  2. #52
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Arrow Encoder & Buttons Mounted and Balanced
    More Progress:
    I was able to mount all of the hardware in the desired location.
    See the pics below:
    Top View:
Size:  105.1 KBName:  Encoder_Mounted_Wide.jpg
    GAME: Can you guess what the buttons are made out of?
    If you haven't got a clue, click here for the answer.
    Bottom View:
Size:  106.6 KBName:  Encoder_Bottom_Wide.jpg
    NOTE: If you look really closely into the housing on the right-hand pic, you'll get to see a glimpse of the encoder and the copper wire in the middle.
    As you can see, the hardware stage is fully mounted and completed.
    However, I need help with programming Girder to work with both the controller and the touchscreen, please.
    Tony: I'd be very thankful it if you'd let me see your Girder commands file.
    Although the events work fine (all 5 buttons and wheel up/down movements), Girder does not differentiate between left clicking on the Controller and on the Touchscreen.
    If anybody could help me with that, I'd really appreciate it.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  3. #53
    May 2004
    UK
    Whats your email address? I will send a girder file, just in case its useful
  4. #54
    Apr 2005
    Quote Originally Posted by Tony G
    Thanks Tony, you've got PM.
  5. #55
    Aug 2006
    Hey guys - I'm looking at having a crack at making one of these, but it appears that RS or Maplin don't stock these encoders any more
    Any suggestions on a UK supplier of the parts and/or new info on things you've come up with over the last few months?
  6. #56
    May 2004
    UK
    I can recommend this encoder from RS:
    http://rswww.com/cgi-bin/bv/rswww/se...ukie&Nr=avl:uk
    This is the encoder I upgraded to. Its 6 + vat but works nicely.
    Have checked RS web-site and its current and in stock.
    Good luck!
  7. #57
    Aug 2006
    Ah brill stuff, thanks Tony.
    Would you believe that I did a search on RS for both "alps" and "encoder" and it came up with nothing...
    Now all I need to do is work out where on earth you can mount this in a Corrado...
  8. #58
    Mar 2007
    Quote Originally Posted by Tony G View Post
    Im very thankful if sam one can give me the grider file too.
  9. #59
    Jul 2005
    netherlands
    Hi people,
    I see that A lot of people including me have problems go get Girder work with the mouse
    can someone place the file or explane how to program.
    I work on an old 67 Mustang with a touch screen build in on the pasagers side.
    I use the original chrome Radio to control the PC, I got the 7 push buttons work with the RR joystick plugin. but I have on the radio 2 double turn knobs and want to have them to work. on the left side was volume and balance on the the right was tune am and tune fm with a steel wire to move the slider (Yes the good old times) the original "display" is now changed by a 2x16 lcd display. when the radio is of it looks totaly original.
    if someone can help to make the radioknobs work please let me know.
    best regards,
    Ralph
  10. #60
    Newbie 06P51GT's Avatar
    Oct 2007
    Olathe Kansas
    current source for elctronic components?
    I just started getting into this idea and would like to build what I have been reading about in this thread. I am a newb to circuitry, but I have tinkered around with it before and would like the challenge. Does anyone know of a current source for an inexpensive rotary encoder and the cool tact switches used in Tony's project? I have found tact switches at radio shack, but I like the ones others have used with the LED's build into them.
    I checked a couple links in this thread, but they are for shops in Europe. I am trying to track down a source for them in the US so shipping is not 3 times the cost of the product to begin with.
    Thanks!
    Bryan
    06P51GT
