Results 11 to 20 of 26
Thread: USB Hub not working after coming out of hibernation
  1. #11
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    Quote Originally Posted by phc
    Search forums for discussion on devcon
    if unplugging the hub (from the computer) and plugging it back in works, you can use devcon to disable the hub before hibernate and enable it after hibernate (like I do).
    Also, what OS are you running?
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
  2. #12
    Aug 2005
    Pennsylvania
    Im running windows xp pro. I just tried the patch not too long ago and it didnt work. It did help though because now the hub is always there instead of malfunctioning sometimes. Ill try using devcon because it eveything does work when i unplug it and then plug it back in again. Thanks
  3. #13
    Jul 2004
    Austin
    Hibernate/standby, resume, battery ac tool
    I made this, mainly to run devcon, but I also have it run syncing software too
    |V1 Virtual Display|
  4. #14
    Aug 2005
    Pennsylvania
    Ok I finally got everything to work right. Turns out my touchscreen was the one causing all the problems after coming out of hiberantion when connected to the hub. So, i just used Devcon and wrote a .bat file to disable it when hibernating and then enable it after coming out of hibernation. I also used Hibernation Trigger to run it. I would've used yours zPilott but Hibernation Trigger delays hibernation to allow the batch file to be run. Thanks for all your help.
  5. #15
    Jul 2004
    Austin
    yeah, that is on the list (should be pretty easy since it would work the same as delaying the shutdown).
    Devcon does run quick enough though that my program will work. I just wish there was some way to find out if the system was going for standby or hibernate (or shutdown or reboot).
    |V1 Virtual Display|
  6. #16
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Quote Originally Posted by OriginalNick2
    hmmm, interesting reading - i'm experiencing problems where my USB -> IDE Connector, when plugged in, prevents my system from booting.
    Its plugged in via a hub but as soon as i remove it the system boots fine,
    i did experience this problem with my USB Pen but it sorted itself out.....
    Any tried the above fix?
    I got this prob every time that I forget to turn on my external HD. (PC hang and I have to reboot, but before this I have to either unplug the usb from the ext HD or turn it on).
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  7. #17
    FLAC -zip-'s Avatar
    Ontario/Canada
    Having problems with USB CD Rom drive at boot up. If plugged in before boot, it hangs at the Bios boot screen.
    If I wait until Windows loads, no problem.
    Grrrr
    Sound Stage
    Eclipse|MTX|Infinity
  8. #18
    Jun 2004
    The North, Manchester
    Any solution to this??
  9. #19
    Aug 2005
    Pennsylvania
    I have no idea. Maybe theres an option in the bios that deals with usb devices on startup?
  10. #20
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    SoCal
    Quote Originally Posted by volum3rider
    Grrrr
    I've seen this happen when I have a USB Thumb drive in during boot up on my PC at work.
    www.mechatroniks.com/wrx - Car PC Project/Dash Kits
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. USB Hub does not show HD after cold boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 04-05-2005, 02:46 PM
  3. Best USB Hub
    By nsmoller in forum Input Devices
    Last Post: 02-08-2005, 04:35 PM
  4. Internal USB Hub?
    By jrich523 in forum General Hardware Discussion
    Last Post: 07-07-2004, 08:44 AM
  5. USB Devices, and Hibernation / Suspend to RAM
    By t0ffluss in forum General Hardware Discussion
    Last Post: 01-06-2003, 09:40 AM
