Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: USB Hub not working after coming out of hibernation
    Aug 2005
    Pennsylvania
    The problem that i'm having is that some of my devices aren't working when coming out of hibernation. I only have two usb slots on the back of my computer and need 5 for my devices.
    Devices I have are:
    Lilliput Touchscreen
    Slim DVD drive in usb case (One USB cable for power and another USB cable to make it work)
    Holux GM-210 GPS
    Wireless USB network adapter
    I have a four port hub and the devices connected to it are the touchscreen, GPS, network adapter, and the usb cable that powers my DVD Drive (it goes from a usb/ps2 connection to a coaxial plug connection). The usb cable that makes the DVD drive work is plugged directly into the computer.
    After hours of trying to see what worked and didnt work, I found that I had to have the DVD drive connected directly to the computer for it to work coming out of hibernation. From there everything else worked and I thought that I was done. But after coming home tonight froma friends house my touchscreen did not work while evything else did. So i unplugged it and then plugged it back in. Then my gps stopped working after that. I thought that maybe there was too many things plugged in so I unplugged the USB power cable for my DVD drive and tried using the ps2 connection to power it. Problem with that is that it makes the drive invisible to the computer after coming out of hibernation. The network adapter always works no matter what so im not really concerned about that. Anybody have any ideas. Is it my hub? I really cant figure this one out.
    Any ideas or help would be appreciated. Thanks.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    haven't I seen this thread before?
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    The wifi could still be the problem if it's USB 2.0 and the others are 1.1. Get another 4-port hub so that you have more options to try. Put the TS and GPS in one and the wifi and DVD in the other. The power should probably go in the first one since those 2 don't take much power.
    This thread does look familiar!
    Maximum Bitrate DeltaFX's Avatar
    France
    Erf, is your hub externally powered ?
    If it is, it certainly requires a 5v 2.2A source.... power it from a 5v molex. 5v rail should be down when hibernating, windoz should redetect all the stuff when resuming from hibernate.
    If this hub isn't powered by anything else than the puter itself, the problem's there. Basically you try to power the hub itself, you tsk, your gps and a wifi dongle with a single source that can only deliver 5v @ 500mA. ...
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    SoCal
    Search forums for discussion on devcon
    www.mechatroniks.com/wrx - Car PC Project/Dash Kits
    Aug 2005
    Pennsylvania
    hub is powered by molex in computer.
    Aug 2005
    Pennsylvania
    ok i tried a few more things and found out that if i put two things devices together in the hub, no matter what those two devices are, one of them wouldnt work. One device might work and then after antother hibernate the other device might not work. Wierd. I think it might be a crappy hub so ill try another one tomorrow.
    phc
    phc is offline
    Aug 2003
    SoCal
    Quote Originally Posted by volum3rider
    I'm having very similar problems without hibernation (my system won't come out of hibernation at all). Randomly at startup, devices and/or hubs won't work properly - until I unplug and re-plug. I've tried 3 hubs (SMC, Netgear and Belkin), none of them fix it.
    Aug 2005
    Pennsylvania
    After doing some googling last night for a fix, I found a usb patch file for via chipsets. Dont know if itll work since its dated 2002 but this is what the patch fixes:
    Question: What issues does this patch address?
    Answer:
    This filter patch is version 1.10 of the VIA USB filter patch. It contains all of the following fixes, listed as a history of which fixes were added by version number of the patch.
    1.02 (1) A connected usb hub that has no usb devices connected will be disabled
    after another usb hub is attached at the another available root port.
    (2) When transfering large of ammounts of data, the system will hang.
    1.05 Fix the issues where the driver will page fault under Windows 98SE.
    1.06 Fixes noise from USB audio converter or speaker.
    Supports usb add-on card.
    1.08 Supports Windows 98 and Windows 2000.
    1.10 Adds support for Windows XP.
    Fix the issue where USB devices will be reenumerated when system resumes from Standby mode.
    The last fix is what got my attention. Ill try it out on my car pc and let you guys know if it helps.
    Jun 2004
    The North, Manchester
    hmmm, interesting reading - i'm experiencing problems where my USB -> IDE Connector, when plugged in, prevents my system from booting.
    Its plugged in via a hub but as soon as i remove it the system boots fine,
    i did experience this problem with my USB Pen but it sorted itself out.....
    Any tried the above fix?
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. USB Hub does not show HD after cold boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 04-05-2005, 02:46 PM
  3. Best USB Hub
    By nsmoller in forum Input Devices
    Last Post: 02-08-2005, 04:35 PM
  4. Internal USB Hub?
    By jrich523 in forum General Hardware Discussion
    Last Post: 07-07-2004, 08:44 AM
  5. USB Devices, and Hibernation / Suspend to RAM
    By t0ffluss in forum General Hardware Discussion
    Last Post: 01-06-2003, 09:40 AM
